Thread: Aug 2017, Beta Release 9
    Default Aug 2017, Beta Release 9
    Download EFILive V7.5
    Download EFILive V8
    We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFlLive recommends beta testers use a separate FlashScan V2 device (when installing the latest beta firmware) and only install the EFlLive beta test software on a separate PC, laptop or virtual machine.
    Release Notes:
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.10 Build 331 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.5 Build 323 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.121 (Aug 14, 2017) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    Issue #3:
    PIDs with text values such as "FUELSYS1" and "FUELSYS2" are not displayed correctly in the V8 scan tool.
    Workaround:
    None. Will be fixed in the next update.
    Issue #4:
    When editing chart properties in the V8 scan tool, clicking in the Y-axis area of a chart to select it for editing has the unintended side effect of resetting that chart's Y-axis min/max values to their defaults.
    Workaround:
    Issue #5:
    Modifying data in the trans section of some CMD/CME files may cause a checksum fault which in turn will cause a flash of that file to fail. V7 may continue to show the checksum as valid, but V8 will correctly show that the checksum is faulty.
    Workaround:
    Oct 2011
    It seems like v7.5 may be calculating CMD checksum incorrectly. Any file saved in v7.5 Beta-8 or Beta-9 will show an invalid checksum in v8. The checksum shown in v7.5 between 2 different calibrations is showing identical.
    03 6spd
    I just tried a file here and it seems ok (OS 22100538), can you please tell me the OS you are seeing this on? Thanks.
    Oct 2011
    I just tried that OS as well as a few others. In any OS is seems to only have issues when a change is made is the trans data.
    03 6spd
    Ok thanks, I get the same result too on changing anything in the trans cals
  1. Aug 2017, Beta Release 8
    Last Post: August 21st, 2017, 01:45 PM
  2. July 2017, Beta Release 5
    Last Post: August 9th, 2017, 11:11 PM
  3. July 2017, Beta Release 4
    Last Post: July 10th, 2017, 03:42 PM
  4. April 2017, Beta Release 2
    Last Post: June 29th, 2017, 03:06 PM
  5. April 2017, Beta Release 1
    Last Post: April 18th, 2017, 02:31 PM
