Results 1 to 8 of 8
Thread: Aug 2017, Beta Release 8
    Default Aug 2017, Beta Release 8
    Download EFILive V7.5
    Download EFILive V8
    We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFlLive recommends beta testers use a separate FlashScan V2 device (when installing the latest beta firmware) and only install the EFlLive beta test software on a separate PC, laptop or virtual machine.
    ** A problem has been identified in the E98 Locking patch for OS's 55503892 and DSP4 65503892, DO NOT apply the locking patch to any tune file using this OS.
    Release Notes:
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.10 Build 330 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.5 Build 322 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.120 (Aug 14, 2017) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Known Issues:
    Issue #1:
    E98 OS 55503892 and DSP4 65503892 locking patch may result in an ECM that cannot be unlocked, please don't lock any ECM using this OS.
    Workaround:
    Working on a fix.
    Issue #2:
    Workaround:
    None.
    Issue #3:
    Workaround:
    Issue #4:
    Some E78 tune files fail to open with the following message: "Unknown bin file format ... Invalid floating point value: 17016-00.08-04-D450".
    Workaround:
    Download the attached E78_calz.zip file and unzip the contents into the folder: C:\Program Files (x86)\EFILive\V7.5\Calibrations, overwrite the existing files.
    Jul 2003
    Thanks for releasing this. I was getting issues with Firmware incompatibility after .19 firmware upgrade tofix the licensing issue.
    Thanks.
    Issue #3:
    Workaround:
    To the E78 folder, correct ...?
    Please note the updated warning regarding the locking patch error for one of the E98 OS's (2016 USA Colorado).
    I ask this because E78_calz.zip unzips tp folder E78_calz.
    Sorry Joe, didn't see your post.
    The workaround should have been:
    Unzip the E78_calz.zip file, then copy the *.calz file from the unzipped E78_calz folder to the \Program Files (x86)\EFILive\V7.5\Calibrations\E78 folder.
    Anyway, an update has been posted here:
    https://forum.efilive.com/showthread...Beta-Release-9
    No worries. Thanks for the update (beta-rel-9).
  1. July 2017, Beta Release 5
    Last Post: August 9th, 2017, 11:11 PM
  2. July 2017, Beta Release 4
    Last Post: July 10th, 2017, 03:42 PM
  3. April 2017, Beta Release 2
    Last Post: June 29th, 2017, 03:06 PM
  4. April 2017, Beta Release 1
    Last Post: April 18th, 2017, 02:31 PM
  5. Release Candidate 2, Aug 19, 2011
    Last Post: September 13th, 2011, 09:58 AM
