Results 1 to 10 of 13
Thread: 4L80e - ECM commanding D4 shift pattern, without a DTC?
    Aug 2017
    Default 4L80e - ECM commanding D4 shift pattern, without a DTC?
    Car is a 5.3/4L80e. I had it running on someone else's ECM with an HPTuners custom OS. No idea what that tune looked like, but the transmission worked like it should.
    I swapped the ECM to a fresh one so I could start working on the tune. I loaded up a 12212156 OS, segment swapped in the 4L80e Express Van transmission calibration and diagnostics, then did the COS3 upgrade. From there I did my best to put together a base tune, and tried to do some driving.
    My transmission is commanding D4 shift pattern regardless of my shifter position. I know this can happen when P1810 is set, but I have no codes. (Well, I had P0452 because I don't have the EVAP in place, but that shouldn't change the shift pattern, right?)
    Changes to the transmission cal:
    WOT shift rpm's raised to 5800
    Torque Reduction Tables zero'd out
    Abuse Mode disabled
    I can command any gear with the scan tool, just not with the shifter.
    Any ideas on what could be causing this issue? Are there other conditions where the ECM would command a D4 shift pattern without setting a code?
    Thanks in advance.
    Try this: go back to the 12212156 + 4L80E seg-swap tune, does trans behave correctly with this...?
    Post your 02020003/COS3 tune file here.
    Aug 2017
    I would have to source a 1 bar MAP to do that wouldn't I? Maybe I can just idle it to check commanded gear or TFP switch status...
    Just try it gently, i.e. drive it round the block, see if it behave properly.
    Are you saying that you only have D4, and when you put it in D3 you still get 1-2-3-4...?
    Aug 2017
    Exactly. I guess it would only take about 15mph to get a 1>2 shift to figure out if that's the issue. I'll see what I can do and report back.
    Aug 2017
    Well I started with the original segment swapped tunes, and GM.TFPSW reads the correct shifter position. It shifts up when it is supposed to hold 1st. When it shifts, GM.GEAR reads 2, GM.TFPSW reads D1... I will revert the transmission parameters back to stock and try again.
    Is your harness wired correctly...?
    I don't see the pid GM.TFPSW, but I see GM.TFPSWS... I'm not sure if this is the correct pid... try this pid: GM.PRND
    Post some logs.
    Aug 2017
    When you add GM.PRNDSW, you get GM.TFPSW as well as GM.PNPSW (an in-gear flag that never changes in my case).
    Looks like I messed something up with my segment swap. I re-did the segment swap to my original base tune, flashed it in and it worked fine. Next I'll do the COS3 upgrade and see where that gets me.
    Segment swaps change more data than just the tables that are available for editing, correct?
    Yes, the segment swap changes hidden data/structure/code.
  1. A50 Shift Pattern Issues
    By jda in forum Allison 5 & 6 Speed
    Last Post: December 17th, 2020, 06:02 AM
  2. 4L60E to 4L80E DTC Settings
    By ferocity02 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 31st, 2014, 11:58 AM
  3. Shift pattern selection
    By PSWired in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 6th, 2012, 10:06 AM
  4. What is Pattern A & Pattern B on the 2010 Camaro 6L80 Tranny Tune??
    By 2010 Bumblebee in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 5th, 2010, 08:06 PM
  5. Can I copy one shift pattern table from one folder to another ?
    Last Post: May 4th, 2010, 08:32 PM
