Results 1 to 5 of 5
Thread: I think I damaged my V2
    Nov 2009
    Default I think I damaged my V2
    I was pulling a tune from a truck to modify and the truck had a bad alternator, the battery had a bad cell too I think. I didn't find any of this out, until after I tried to read it. It would read about half of the PCM and stop, so I cycled the key and tried a second time. Same result. I told him something wasn't right , and lifted the hood. That"s when he told me he had a few "electrical problems". (I won't connect to another vehicle before a good inspection in the future!!)
    After lifting the hood, I immediately removed my equipment. There were spliced wires and jumpers all over the back of the fuse/rely center, which was pulled out and flipped. Long story shot, I cannot get V8 or V7 to recognize my V2 when its plugged in.
    I figured this out when I went to modify a tune for my truck, and I kept getting the "Demo" message. So, I tried to use V8, and it will continually tell me there is nothing plugged it.
    When I plug it into my laptop, all the leds light, and it goes back blank for a few secs, then the orange led second from the right blinks. After that, the screen is just blue, and the software will not recognize it.
    If I plug it into my 09 Tahoe, I can get the screen to read, but some of the function and buttons don't respond.
    I'm going to reinstall the software, but does anyone have any suggestions on what to do? I'm kind of worried about this...............
    Doing my best to fix what ain't broke!!
    If you get the blue screen lighting up but no actual loading/booting of the unit, check your USB drivers on your laptop. Use the EFILive USB Manager and remove the drivers, reboot your system, then use the same tool to re-install the drivers.
    Nov 2009
    I do need the usb driver, because if I look for the Flashscan V2, is reads that the usb driver is unavailable!!
    Thanks, I'll try reinstalling them, didn't think about this.
ID:	21383   Click image for larger version.
    Nov 2009
    Scarab I owe you a Beer, or a case!!
    That was it!!
    Everything is back to normal, gonna go try to read my tune now.
    Thanks again!!
    Quote Originally Posted by Scatfish View Post
    That was it!!
    Thanks again!!
    Glad it was a simple driver issue! No problem, now get back to tuning!
  1. Do I need to buy another tuning license for a replacement ecm? Damaged ecm
    By mvvette97 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 15th, 2016, 12:11 PM
  2. Have I damaged my V2?
    By Gelf VXR in forum FlashScan V2 BB Logging
    Last Post: May 27th, 2008, 08:57 AM
  3. Autotuning damaged my Boost gauge
    By dc_justin in forum General (Petrol, Gas, Ethanol)
    Last Post: December 15th, 2005, 03:32 AM
