Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Auto VE , Auto Maf, PE & Timing Adjustment
    Jun 2016
    Default Auto VE , Auto Maf, PE & Timing Adjustment
    Hi guys
    I would like to tune my LS1B the old way (doing it in a single log just confuses me more) can someone summaries the tuning process step by step?
    1-VE adjustment (well understood using the Auto VE write up)
    2-MAF Adjustment ( is there a write up on this?)
    3-PE & Timing adjustment
    I am using a serial link between my LM2 and V2 as a friend helped validating the CalcBen1 & EXT.WO2AFR.
    at this moment, I tuned my VE successfully and need guidance to complete the tune.
    also, is there a write up to create/validate pids that are not available on the existing PID files?
    Please excuse me for my ignorance as I am new to the tuning world.
    Thanks,
    00 Camaro Z28
    398ci lq9 w/ ls9 heads , Holley Hi ram intake
    Th-400 , 5k stall
    9.7 cr - 94mm BW Turbo
    Super Street
    03 Sierra, L92
    398Rwhp/416Rwhp
    yep. check out the auto-ve tuning tutorial from the scanner or editor.
    Help--->Tutorials
    Jun 2016
    00 Camaro Z28
    Th-400 , 5k stall
    Super Street
    03 Sierra, L92
    398Rwhp/416Rwhp
    Quote Originally Posted by maalmull View Post
    2:
    this is just like 1. except you disable VE (set B0120 to zero) and log GM.MAFFREQ, and you create a map to mimic the MAF table B5001.
    aka AutoMAF.
    3:
    without dyno: set PE to something like EQR 1.175 and timing to stock 2002 F-car HO and LO spark tables (note: uses LO when MAF is failed during AutoVE).
    with dyno: start at PE EQR 1.175 and stock spark timing, make adjustment and check what dyno shows; when you increase timing and/or decrease PE EQR and torque barely goes up, back off that adjustment (give you a safety margin); if you see knock, decrease timing and/or increase PE EQR; remember, these are fast burn combustion chanbers, they don't need as much timing as SBC; pay attention to engine coolant temp.
    Jun 2016
    Thanks Joe
    I am running a stock LS1 in a 03 single cab sierra with 317 heads unported milled to .020 and running 215/223 112 cam & stock truck intake with the 25 truck stock injectors.
    My TP in idle is like 9% and AFR fluctuates from 12.xx to 15.xx
    Any suggestions?
    00 Camaro Z28
    Th-400 , 5k stall
    Super Street
    03 Sierra, L92
    398Rwhp/416Rwhp
    Jun 2016
    I also based my tune on the truck file not using an Fbody HO , LO tables.
    Do u suggest 28 injectors ?
    00 Camaro Z28
    Th-400 , 5k stall
    Super Street
    03 Sierra, L92
    398Rwhp/416Rwhp
    Questions:
    a. is your throttle DBW...?
    b. how much power are you expecting to make...?
    c. do you have wideband...?
    d. do you have dyno time...?
    Note: truck calibrations are slow to enable PE (PE TP enable is 90% which is too late, PE enable counter is 1 second or more which is also too late).
    Jun 2016
    Questions:
    A/ yes it's DBW
    B/ won't go more than 400rwhp
    C/yes I am running a serial lm2 wb
    D/won't have an access to a dyno until November.
    I adjusted the PE TP to 60% and changed PE enable counter to zero.
    I would like to note that car runs way better on open loop and that CL just mess the car up.
    00 Camaro Z28
    Th-400 , 5k stall
    Super Street
    03 Sierra, L92
    398Rwhp/416Rwhp
    a. If DBW then log the pid GM.ETCTP, see what this says.
    b. 400 rwhp = about 435-450 fwhp: injectors are limited, you might need at least 32 lb/hr.
    PE enable: look at 2002 F-car (65%-35% split enable).
    CL: what are O2 switch points (see table B4105), try setting all of them to 450 mV.
    Is this with or without MAF...?
    Jun 2016
    I will go thru your advice and log ETCTP.
    Yes the MAF is still there as you know it's a 5pin.
    I've a 28 injectors laying around do u recommend installing those and copy the injector tables from an fbody ?
    00 Camaro Z28
    Th-400 , 5k stall
    Super Street
    03 Sierra, L92
    398Rwhp/416Rwhp
  1. what to do for MAF after doing auto VE
    By supershift67 in forum Gen III V8 Specific
    Last Post: November 1st, 2012, 03:01 PM
  2. Auto VE or Calc VET or Auto Maf?!?!
    By Nver2loud in forum Gen III V8 Specific
    Last Post: October 23rd, 2012, 05:08 AM
  3. Auto MAF (the begginning)
    By kwhiteside in forum Gen III V8 Specific
    Last Post: July 16th, 2009, 06:55 AM
  4. Auto VE and MAF
    By kistlerjm9 in forum Gen III V8 Specific
    Last Post: April 8th, 2009, 03:20 PM
  5. Auto VE for MAF?
    By PRAY in forum Gen III V8 Specific
    Last Post: January 12th, 2008, 07:56 AM
