Results 11 to 20 of 21
Thread: Auto VE , Auto Maf, PE & Timing Adjustment
  1. #11
    Quote Originally Posted by maalmull View Post
    I've a 28 injectors laying around do u recommend installing those and copy the injector tables from an fbody ?
    For 400 rwhp, I would try these, and log injector duty cycle (to see if they max out).
  2. #12
    Jun 2016
    will go through all the points
    I Appreciate ur help.
    Sent from my iPhone using Tapatalk
    00 Camaro Z28
    398ci lq9 w/ ls9 heads , Holley Hi ram intake
    Th-400 , 5k stall
    9.7 cr - 94mm BW Turbo
    Super Street
    03 Sierra, L92
    398Rwhp/416Rwhp
  3. #13
    I would like to note that car runs way better on open loop and that CL just mess the car up.
    Is this with or without MAF...?
    Yes the MAF is still there as you know it's a 5pin.
    I mean: when it does this, is it running from MAF or VE (I take it it's this)...?
  4. #14
    Jun 2016
    Running completely from MAF (B0120 set to zero).
    I am in doubt that I am doing the AutoMaf the wrong way.
    After completing the AutoVE. Do I copy the VE table to the original file and then set the B0120 to 0 to eliminate the VE and create B5001 , log , then multiply paste in MAF calibration?
    00 Camaro Z28
    Th-400 , 5k stall
    Super Street
    03 Sierra, L92
    398Rwhp/416Rwhp
  5. #15
    Yes, copy new VE to original file (which has MAF enabled) and save as new filename... then set B0120 to zero, make map to mimic MAF table B5001, log, multiply-paste map into MAF table B5001...
    BUT, also, if you're using wideband, you should be disabling CL/LTFT/STFT (for both AutoVE and AutoMAF)...
    otherwise the wideband will just read stoich (unless the trims peg).
  6. #16
    More info, see posts #4 and #29 (read carefully): Summary-Notes
  7. #17
    Aug 2013
    This is REALLY important! Always keep a copy of your original file. When you make any changes, give the updated tune file a new name. If you change a lot of things and mess up your tune (which can happen), you'll have the original file to go back to... and you can then start tuning from that original file again.
  8. #18
    Jun 2016
    Extremely useful
    will have to go though these notes very carefully before asking any further questions.
    Thanks a bunch!
    00 Camaro Z28
    Th-400 , 5k stall
    Super Street
    03 Sierra, L92
    398Rwhp/416Rwhp
  9. #19
    You can still ask questions, that's no problem... ...I simply meant they are very detailed so they need careful reading.
  10. #20
    Jun 2016
    Thanks Joe you've been a great help .
    I tuned the car but still facing problems:-
    1/ first runs , car runs strong (car still on open loop & no mass air involved). On idle I noticed the engine " hood" is shaking & rattle a little bit. Also noticed I am getting knock retard even if I reduce timing on that specific rpms.
    2/ started the car next day and the car surges and engine shakes/ rattle strongly and no performance ( check engine is on) and I am getting P0300.
    Logged ltft's and they are + 10%
    Is there any thing to log that may help narrow were the problem might be?
    I am confident it's mechanical problem and have a feeling it's fuel system related ( not checked fp yet). I suspect FPR or Fuel pump.
    Any suggestions ?
    00 Camaro Z28
    Th-400 , 5k stall
    Super Street
    03 Sierra, L92
    398Rwhp/416Rwhp
  1. what to do for MAF after doing auto VE
    By supershift67 in forum Gen III V8 Specific
    Last Post: November 1st, 2012, 03:01 PM
  2. Auto VE or Calc VET or Auto Maf?!?!
    By Nver2loud in forum Gen III V8 Specific
    Last Post: October 23rd, 2012, 05:08 AM
  3. Auto MAF (the begginning)
    By kwhiteside in forum Gen III V8 Specific
    Last Post: July 16th, 2009, 06:55 AM
  4. Auto VE and MAF
    By kistlerjm9 in forum Gen III V8 Specific
    Last Post: April 8th, 2009, 03:20 PM
  5. Auto VE for MAF?
    By PRAY in forum Gen III V8 Specific
    Last Post: January 12th, 2008, 07:56 AM
