Results 1 to 10 of 20
Thread: E38 VVE Dial In Guide Guidance Needed
    Junior Member spedracr93's Avatar
    Jun 2016
    Question E38 VVE Dial In Guide Guidance Needed
    E38 VVE Dial In AEM.Analog.pid
    AVALANCHE 2007 6.0 Conversion LS3 VVE Tutorial _002.ctz
    I am looking for help with my first E38 VVE Tune.
    Vehicle is a portly, 2007 Chevrolet Avalanche with the L76 6.0, 4L70E & 4.10 diff. Originally equipped with VVT & AFM, I have removed all of that with a recent engine rebuild for a GM LS3 cam (after the second AFM lifter failed in 5,000 miles, mind you). To tune the computer, I removed the AFM and VVT and copied the stock 2008 Corvette B8101 table and inserted it into the original L76 tune (same cam & heads but different intake and ever so slightly less displacement). Everything is as it should be, no codes but relatively poor performance in a few areas other than light load cruise.
    This is my first attempt at tuning the E38 and I feel like I have followed every point and verified by taking notes of every single stock parameter that will be changed back after tuning.
    I think that I do not have my BEN MAP properly established, but I would like a second opinion. If I were to give any feedback on Swingtan's guide, it would be that this is a seemingly critical data point and for a tutorial, it should probably be well defined instead of non-existent (Not to say that I'm not grateful for the guide or the subsequent help I'm seeking here, just merely pointing out a shortcoming of that tutorial).
    Attached is the tune and my PIDs. Any advice to upload a log that is 2.48 MB??? Also, I was going to upload my BEN MAP for reference but that is an invalid file type for this forum...
    I am using an AEM 30-0334 UEGO through Analog's AD1 port on the V2 for reference.
    I'm open to ideas and comments.... any help/discussion would be beneficial.
    Please attach your most recent log file, and your calc_pids.txt file.
    Can you zip the log file (create compressed folder out of it ** see below), post the .zip file.
    To upload your BEN map, zip it also, post the .zip.
    ** to zip a file, on the file's icon go rightclick->Send To->Compressed (zipped) Folder and you will see a .zip file with the same name appear on your desktop.
    Jun 2016
    Thanks, Joe. I didn't think about zipping.
    Here are the 4 files (1. BEN MAP, 2. TUNE, 3. LOG, 4. PID .TXT)
    {B8101} VVE - AEM WBO2 AFR MAP.zip
    AVALANCHE 2007 6.0 Conversion LS3 VVE Tutorial _002 TUNE.zip
    avalanche vve 1 LOG.zip
    calc_pids.txt
    Jun 2016
    To further describe what is happening... I am removing low cell counts and applying my filter before performing a "Copy with Labels" in the Scan Log, then performing a "Paste and Multiply with Labels" in the Tune's B8101 table.
    Here is my Graph Before the Paste:
Name:	VVE Graph BEFORE.jpg
    And here is the Graph After the Paste:
Name:	VVE Graph AFTER.jpg
    edit your calc_pids.txt to read as follows (add the red part):
    Code:
    *CLC-00-110
    factor             0.5           1.5       .4  "{CALC.AFR_AEM.lambda}/{SAE.LAMBDA}"
    ( use an editor like Notepad, i.e. not Word )
    Do you have the pdf for your AEM wideband, I want to check the V->AFR/lambda equation.
    Aug 2013
    How are you doing your calc.dat without logging ECT?
    For E38/E67/E92 we take a shortcut, we use SAE.IAT for CALC.DAT (since I could not see any IAT/ECT blending tables).
    Jun 2016
    Thanks, Joe. I'll update that reference in the PID file.
    Here's the page showing equation and table:
Name:	30-0300 X-Series UEGO Gauge.jpg
    Or PDF:
    30-0300 X-Series UEGO Gauge.zip
  1. E38 / E67 VATS disable guide
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: March 22nd, 2023, 01:35 PM
  2. E38 VVE Setup Guide
    By swingtan in forum Tutorials
    Last Post: October 3rd, 2020, 07:30 AM
  3. Please help me tweak my E38 VVE.
    By Jayrcr3 in forum E37, E38 & E67 PFI ECM's
    Last Post: November 30th, 2011, 07:40 PM
  4. Need E38 VVE tuning help
    By 2007chevy5.3l in forum E37, E38 & E67 PFI ECM's
    Last Post: November 26th, 2011, 08:34 PM
  5. E38 afm vve
    By VEGASROBBI in forum E37, E38 & E67 PFI ECM's
    Last Post: March 1st, 2010, 06:40 PM
Tags for this Thread
