Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 66
Thread: Having trouble lately with higher IAT
  1. #31
    Nov 2011
    I still have the stock injectors. In theory i would swap them and see no change right? Leaving everything as is.
  2. #32
    Aug 2013
    If the stock injectors are the same part number then yes, you should see no change if you leave the tune as it is. If you go lean on the stock injectors then they are flowing less than your current ones and if you go rich then they are flowing more than your current ones.
  3. #33
    Nov 2011
    Got dirty. Part #0280155868. Not stock. Googling tells me anything from 36lb to 42lb I'm guessing those numbers come from different rail pressure. Don't know if I have the right injector data or not. Would post but it won't let me attach an Excel file. Could have sworn there were excel files on here before.
  4. #34
    Aug 2013
    That's interesting. They should be flowing around 40lbs @4bar. Either your fuel pressure is really low, or your MAF is over-reading airflow for some reason.
    We can test this if you want to run some logs for me.
  5. #35
    Nov 2011
    I can take some logs. First I should probably put the right injector data in there.i think I have b3701, b4003, b4005 and whichever the IFR table is I don't remember.
  6. #36
    Aug 2013
    I'll set up a tune file for you to use. We need to be in MAF only mode for this test. The starting data is not important... I'll be adjusting the data from the logs.
  7. #37
    Nov 2011
    Also, I have not seen a lean condition at wot, cant imagine fuel pressure is low just based on that, but stranger things have happened so it's worth testing.
  8. #38
    Aug 2013
    Flash this tune file in and run me a log. As well as what you were logging for me last time, add vehicle speed and commanded AFR.
  9. #39
    Aug 2013
    Also, try to get me around 12,000 frames at full operating temperature. Avoid going into PE mode if you can.
  10. #40
    Nov 2011
    Added wideband lambda as well. The sensor is old, but hopefully atleast close to right. Calibrated it before putting it back in. I also notice the voltage seems low. Thats something I'll have to look in to.
  1. hesitate at higher speeds??
    By ryanb in forum Duramax LB7
    Last Post: February 7th, 2013, 05:19 PM
  2. Sparks Higher than we are asking
    By Forcefedperformance in forum Gen III V8 Specific
    Last Post: April 22nd, 2010, 07:02 AM
  3. What happens when I set a value higher than the tables know?
    Last Post: August 1st, 2009, 02:32 AM
  4. more air = higher compression?
    By jchev502 in forum Vortec V6/V8 Specific
    Last Post: July 19th, 2008, 09:21 AM
  5. Lean idle w/ higher IAT temps
    Last Post: September 14th, 2006, 03:03 PM
