Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 66
Thread: Having trouble lately with higher IAT
  1. #11
    Nov 2011
    Also a 103mm MAF housing and card style MAF sensor.
  2. #12
    Aug 2013
    Would you like to add fuel injectors to your list?
  3. #13
    Nov 2011
    Quote Originally Posted by statesman View Post
    Ah yes. 42lb injectors. Apologies, this car has been modded over the years and doesn't get much attention these days. I should add no cats, 3" x-pipe, aluminum flexplate, bigger alternator and turn one PS pump.
  4. #14
    Aug 2013
    Now we're getting closer to full disclosure.
    Do you intend on tuning this thing properly, or do you just want a quick fix to stop it taking a dump everytime you pull up at lights on a hot day?... there's no right or wrong answer here, I just need to know what you want.
  5. #15
    Nov 2011
    I'd like to tune it properly. Any advice is appreciated.
  6. #16
    Aug 2013
    First thing you need to do is to get the B9021 cax file. It's somewhere in the cax section of this forum (I don't have a link to it so you're going to have to go and find it for yourself). Read the instructions carefully and put the correct cax file (renamed to your OS) in the calibration folder. When you next open the tune tool, it will appear under Injectors > Parameters.
    Then...
    Change {B9021} to 0.55
    Change all values in {B4003} and {B4004} to 0.55
    Zero out all values in {B4005}. (It will be wrong, but not as wrong as what you have now)
    Then do a log for me. Include in your log...
    MAF Frequency
    MAF airflow
    RPM
    MAP
    ECT
    IAT
    GM Volts
    Short term trims
    Long term trims
    IAC counts
    Wideband (if fitted and calibrated)
    No need for any WOT pulls, just normal driving.
    Post your updated tune file with the log.
  7. #17
    See post #12: need-B9021-for-01250003
  8. #18
    Nov 2011
    Ok I'll get that set up. Don't know why I haven't read anything about the B9021 cax.
  9. #19
    Aug 2013
    Quote Originally Posted by spy2520 View Post
    It's a closely guarded secret... there's probably only a few thousand people in the whole world that know about it.
  10. #20
    Probably only a few thousand.
  1. hesitate at higher speeds??
    By ryanb in forum Duramax LB7
    Last Post: February 7th, 2013, 05:19 PM
  2. Sparks Higher than we are asking
    By Forcefedperformance in forum Gen III V8 Specific
    Last Post: April 22nd, 2010, 07:02 AM
  3. What happens when I set a value higher than the tables know?
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 1st, 2009, 02:32 AM
  4. more air = higher compression?
    By jchev502 in forum Vortec V6/V8 Specific
    Last Post: July 19th, 2008, 09:21 AM
  5. Lean idle w/ higher IAT temps
    Last Post: September 14th, 2006, 03:03 PM
