Page 7 of 7 FirstFirst ... 567
Results 61 to 66 of 66
Thread: Having trouble lately with higher IAT
  1. #61
    Aug 2013
    Winter cold starts should be a lot easier to dial in now that your IAC effective area table is in better shape.
    When you log this update... start logging before you start the engine so I can see the engine start-up in the log.
  2. #62
    Nov 2011
    Latest log. Looks like the IAC is going to zero steps again. Don't know why it would do that on this log. Nothing else has changed. I don't know if i can close it much more than it is.
  3. #63
    there's now too much physical air causing the PCM to drive IAC all the way down to zero (i.e. and now PCM can't reduce/control the amount of air)...
  4. #64
    Aug 2013
    Quote Originally Posted by spy2520 View Post
    Your idle trims are very consistent now... which makes me think that your IAC valve has just lost its way. Try doing an IAC reset.
  5. #65
    Good point.
  6. #66
    Nov 2011
    Hmm I'll give that a shot.
  1. hesitate at higher speeds??
    By ryanb in forum Duramax LB7
    Last Post: February 7th, 2013, 05:19 PM
  2. Sparks Higher than we are asking
    By Forcefedperformance in forum Gen III V8 Specific
    Last Post: April 22nd, 2010, 07:02 AM
  3. What happens when I set a value higher than the tables know?
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 1st, 2009, 02:32 AM
  4. more air = higher compression?
    By jchev502 in forum Vortec V6/V8 Specific
    Last Post: July 19th, 2008, 09:21 AM
  5. Lean idle w/ higher IAT temps
    Last Post: September 14th, 2006, 03:03 PM
