Results 1 to 3 of 3
Thread: LB7 20 over injector help
    New Member Luvss350's Avatar
    Oct 2014
    Default LB7 20 over injector help
    This is my first post here and i think im in the right spot
    My dad has a 04 duramax LB7 we just did head gaskets and 20 over injectors and installed a fast 150 lift pump and now the truck has a bad bog leaving intersections. We cant figur out why it bogs. The bog hapens stock tuned(100% factory) or with the edge chip in it or with efi live in it (what little i know about tunning diesels) i corrected the injector polse width.
    The bog is from idle to about 1800-2000 rpm then the truck black smokes and takes off (my dad dose not want black smoke) if you let off the throttle and get in to it agian and rpm are above 2000 no bog it only hapens if the rpm drops below 2000
    Other mods the truch has is a air aid air filter and intake and changed the wastgate on turbo and a bd disel stage 3 tranny and i think thats everything
    Any help would be grate we are going on a long trip next week and need to get it figured out
    Dec 2013
    Re-evaluate the wastegate function. The bog is not related to your injectors. Also ensure there are no air leaks intake or charge piping side.
    Oct 2014
    Will do
  1. LB7 injector balance rates
    By minytrker in forum Duramax LB7
    Last Post: August 24th, 2014, 01:51 PM
  2. 01 LB7 PCM in 04 LB7 truck?
    By KLUG'S SS in forum Duramax LB7
    Last Post: December 26th, 2013, 01:25 AM
  3. LB7 / LLY Injector assignment dispute
    Last Post: December 29th, 2012, 12:43 AM
  4. Noob with LB7 injector issue
    By Mr.Duck in forum Diesel
    Last Post: September 12th, 2011, 09:53 AM
  5. LB7 Fuel Injector balance rates reading 0
    By StuntHeavy in forum Duramax LB7
    Last Post: July 7th, 2010, 01:03 PM
