well, I looked through everything again... I must be missing something... can I get a link with directions on where to find the instruction for preparing the map? ive followed what I can gather and this is what I came up with:
I would like to add I'm using the innovate mtx-l plus analog out with flashscan v1.... thus far the only pid that seems correct is LC-1, is this the right option? I do not see an option that is clear cut for this wideband
I will try to find a way (probably the wrong one!) to try to make it be as I think it should
