hey there, just found another table that is urgently needed for the Colorado's here in NZ. The table I found in this video :
https://www.youtube.com/watch?v=HKu80j0bUHk detailing some tuning on a LBZ engine. The table is called B1122 Torque Fuel Limit RPM conversion.
I'm assuming theres a similar table in the LTZ Colorado as its the same ecu USED IN EACH. When I'm tuning these engine the fuel hits a brick wall at 104mm3 and flat lines until the commanded torque starts to drop off over 3200rpm. It just happens that this table in the video has a figure of 104mm3 in it which is what I am getting as a brick wall.
Can you confirm this is the problem ?
O/S 55500370
thanks,
Mike Ekdahl in NZ
