Results 1 to 5 of 5
Thread: CKP Relearn
    Aug 2014
    Default CKP Relearn
    I have a V1 Flashscan and need to do a CKP relearn. With the last set of modifications to the engine I had a dyno tune done on the car and the tuner used HPTuners with a 2 bar OS. When I go into the bidirectional tab of the EFILive Scan software there is no option on the dropdown for the relearn. I'm assuming the issue is the with the HPTuners 2 bar OS in the ECM I can't use EFILive to perform the relearn? Any other options? e.g. can a TechII/III at a dealership still perform the relearn with the custom OS or do I need to get my hands on HPTuners?
    p.s. the place that tuned my car is several hours away so I can't get their in a practical way
    Car is an '04 Cadillac CTS-V (original LS6 ECU) with a Magnuson supercharger added.
    In the V7 scantool goto the DVT tab.
    Do you know how to do it (after you initiate it from the scantool you have 10 seconds to bring RPM up over 4000 rpm, as soon as it stumbles release throttle and let it spin down to idle, switch engine off, wait up to 15 seconds).
    Aug 2014
    Turned out that I wasn't getting a crank signal at all so the relearn wasn't the problem after all. Thanks anyway!
    ok, glad you found it... what caused it...?
    Aug 2014
    Poor engineering My son had the wires for the crank sensor and the oil level sensor swapped. Who thought that having plugs similar enough that they could be swapped that close together was a good idea?
    Anyway, it's running now
  1. CKP Relearn Question
    By BobR in forum General
    Last Post: October 7th, 2009, 11:37 AM
  2. CKP (CASE) Relearn Question
    By Haans249 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2009, 05:58 AM
  3. Problems with CKP relearn on 2001 12200411 PCM
    By S10Wildside in forum General (Petrol, Gas, Ethanol)
    Last Post: April 16th, 2009, 04:29 AM
  4. CKP Relearn
    By 91LS1S10 in forum Gen III V8 Specific
    Last Post: January 17th, 2009, 06:03 PM
  5. CKP Relearn
    By 91LS1S10 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 29th, 2006, 07:21 AM
