Thread: E38/T42 running stand alone
    Jan 2014
    Default E38/T42 running stand alone
    Stupid quick question-
    LY6(keeping VVT) with 4L65E, the preferred ECM/TCM would be E38/T42 correct? and these will run standalone just fine with no BCM?
    A/C and all gauges will be canbus? nothing discrete?
    Should be pretty straightforward, I'm not sure what used E38/T42 with a 4L60/65/70E (Express Vans have the LY6+4L80E from 08-09) combo. Yes, just those 2 modules without a BCM. Can't speak to the gauges, that can be a function of the platform of the OS (truck vs Vette vs Camaro, and so forth).
    I'd use the Express van ECM OS and TCM OS (4L80E), then segment swap in the TrailBlazer SS Trans and Trans Diag segments (4L70E) and disable the ISS. I know the OS #s line up for 2008. 2009 4L70Es have a different setup (no 3-2 solenoid I believe) so stick to 07-08.
    Last edited by ScarabEpic22; December 7th, 2017 at 05:59 AM. Reason: Corrected years
    Mar 2009
    I think an 08 silverado E38 and T42 trans controller will work too. Did the express vans come with VVT?
    Quote Originally Posted by LastCall View Post
    Yes they did, the LY6 engine has AFM and VVT. A Silverado with E38/T42 would work too and would likely have the same TCM OS # as the TrailBlazer and Express making it another good candidate for segment swapping.
    Nov 2005
    Should be pretty straightforward, I'm not sure what used E38/T42 with a 4L60/65/70E (Express Vans have the LY6+4L80E from 07-09) combo. .
    2008-2009 only.
    2007 Express van was still Gen III/LS1b PCM.
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Jul 2003
    12617631/24239927 is a great combo.
  1. Running stand alone T43 with E40
    By rally1 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: April 7th, 2013, 01:58 AM
  2. e38 stand alone
    By proflash in forum E37, E38 & E67 PFI ECM's
    Last Post: November 10th, 2009, 03:57 PM
  3. Questions about the E38 as a Stand Alone
    By MSURacing in forum E37, E38 & E67 PFI ECM's
    Last Post: September 4th, 2009, 10:15 AM
  4. E38 Stand alone problems
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: August 27th, 2009, 09:05 PM
  5. E38 stand alone
    By v8vegaman in forum Gen IV V8 Specific
    Last Post: April 10th, 2009, 07:54 AM
