Results 1 to 10 of 10
Thread: 2917 Chevrolet SS Unrecognized PCM
    Lifetime Member mistermike's Avatar
    Dec 2003
    Default 2917 Chevrolet SS Unrecognized PCM
    Hello. I've been away from the board for a few years, so please forgive any loss of grey matter or lack of familiarity with the latest knowledge.
    The CTZ file has been submitted to support by email, but I'm curious as to whether anyone has had any success with this model year. O/S is 12673958. The supported models lists the Chevy SS only through 2016, but does list the 2017 Holden Commodore / HSV as supported. Current EFI Live 7.5 shows all the VIN, O/S, MFG info, etc but returns an "unrecognized PCM message, and obviously cannot edit the tune.
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
    Mike, which V7 build version do you have...?
    Dec 2003
    Hey Joe,
    I'm running 7.5.10 build 323
    Junior Member pir4te's Avatar
    May 2011
    Are you able to post the .ctz read?
    +1 post your tune file.
    Dec 2003
    Here goes
    2107 SS Stock.ctz
    Sorry about the dyslexic file name
    I can open it with build 335... see here: Sep-2017-Release-Candidate-1
    Dec 2003
    I'll give it a try and report back.
    May 2011
    Yes fine on beta 330.
    I was interested to compare whether there was any indication that the Driving Mode accords to presets in the tune, as many believe.
    The proposition is that mode changes switch throttle rate and torque delivery. Possible, but don't see any indication from data displayed.
    Dec 2003
    It's a miracle! The RC! releases did the trick.
    Interestingly, I had to disable my Avast antivirus to get the installers to run. Something in there really ticked off Mr.Avast. Better safe than sorry, I suppose.
    Thanks so much Joecar! You're a mensch.
    I've really got a lot of catching up to do. I go back to the days when EFI Live was scan-only using the Autotap dongle, but I am amazed at the progress of you dedicated fellows have achieved. A tip of the hat to Paul and Ross as well.
    PR4TE, that's an interesting proposition. I'm just getting to know the car. I suspect most of the mode changes relating to steering response and damper programming likely reside in the BCM, if not specialized modules. Muffler valves, I haven't a clue. Helms has not yet published a service manual for the 2017, but I'll have one as soon as it's available.
    I'm considering purchasing a second PCM to do tuning on, and keep the original a virgin for warranty purposes, unless there are low level hacks to spoof the nannies.
  1. UNRECOGNIZED PCM Please Help!
    By cumminsDK in forum Cummins 6.7L
    Last Post: March 10th, 2016, 03:49 PM
  2. unrecognized pcm??
    By TorqueDieselLLC in forum Cummins 5.9L
    Last Post: June 5th, 2011, 05:07 PM
  3. Unrecognized PCM
    By Meister in forum E37, E38 & E67 PFI ECM's
    Last Post: October 10th, 2010, 09:47 AM
  4. Unrecognized PCM
    By Rocketman69 in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: January 10th, 2008, 01:11 PM
