Results 1 to 4 of 4
Thread: 12587603 & 12212156 Auto Trans Shift RPM Drop Ratios
    Jul 2003
    Post 12587603 & 12212156 Auto Trans Shift RPM Drop Ratios
    Hello Guys,
    This is a very nifty thing I've used to calibrate correctly high stall converters so the torque management works as intended.
    12587603
    Code:
    [D1111]
    ;         Description
    DESC.001 = Used to calculate the timing of the upshift
    DESC.002 =
    DESC.003 =
    DESC.004 =
    ;         Seg Caption                          Major            Minor            Vis Dis 2D Grp
    VIEW =      4 "RPM Drop Ratios"             "Desired Shift Times" ""                1   2  0   0
    ;         Address(es)                      BitOff Bits Typ Inv
    ADDR =    1CE04                                 0   16 UNM   0
    ;         Units    Factor         Offset Prec MinLimit MaxLimit MinUser  MaxUser
    SI_SLOT = Factor    0.0002441406         0    4        0       7.999756        0       7.999756
    IM_SLOT =
    ;         Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ;         Units            Labels
    SI_COL =  Event        "StartShift,EndShift"
    IM_COL =  Event        "StartShift,EndShift"
    SI_ROW =  Gear   "2nd,3rd,4th"
    IM_ROW =  Gear   "2nd,3rd,4th"
    12212156
    Code:
    [D1111]
    ;         Description
    DESC.002 =
    DESC.003 =
    DESC.004 =
    ADDR =    1A5FE                               0   16 UNM   0
    IM_SLOT =
    ;         Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ;         Units            Labels
    Enjoy
    Highlander, thanks.
    Jul 2003
    No problem
    May 2022
    I am a total newbie, but I desperately would like some help with this. Im using a different tuning suite, but I do have efilive and my endless searching to fix a tm issue with a high stall converter has led me here.
  1. IAT CAX File for 12587603 and 12212156
    By Highlander in forum CAX Files
    Last Post: February 24th, 2020, 02:29 PM
  2. 4l60E Trans Shift VSS Vs Rpm
    By Mr98z71 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 10th, 2015, 12:37 AM
  3. RPM drop with TCC lockup?
    By DrX in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 7th, 2006, 01:47 PM
  4. Auto Trans & Mafless
    By johnv in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 25th, 2005, 08:27 AM
