Results 1 to 4 of 4
Thread: Can I scan/log my 2017 Z06 with my V2 that is Only Cummins Licensed
    Oct 2015
    Question Can I scan/log my 2017 Z06 with my V2 that is Only Cummins Licensed
    I have a V2 that I've been logging and tuning my 5.9 cummins with for a while now but would like to scan and log my new 2017 Z06 (E92?). Is this possible even though it's only licensed to tune cummins?
    If possible is it just a matter of setting up a new BBX file on the V2?
    Thx
    You can scan/log any supported vehicle with a FlashScan V2, regardless of Tuning option(s) enabled. Only when you go to flash a controller do you need to have the proper Tuning option AND a spare VIN license available.
    If you want to tune your Z06, you will need to purchase the GM Tuning option which comes with 2 additional VIN licenses.
    Yes, just setup a new BBX file or use pass-through logging.
    Oct 2015
    Thanks Erik
    Knew that I'd need to add the GM license to tune just wasn't sure if I could scan/log. Not sure yet if I'll tune this one myself after looking at all the tables in a stock file
    I do have prior experience data logging with wideband O2's and tuning the LS6 in a 2003 Z06 that I use to own so it's not out of the question. I've also custom tuned the ECU in my 2009 Hayabusa for LSR (land speed racing).
    The E92s add a handful of complexity, but they're closer to diesels in that injection timing is much more important. There are a ton of tables that all interact even closer than the Gen III and Gen IV ECMs!
  1. 2016 or 2017 Stock Z06 LT4 file??
    By Longslyde in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 15th, 2017, 06:54 AM
  2. Replies: 4
    Last Post: January 3rd, 2013, 08:15 PM
  3. Replies: 4
    Last Post: September 10th, 2010, 01:38 PM
  4. log and tune files from stock 06 Corvette Z06 urgent needed
    By Treurentner in forum Gen IV V8 Specific
    Last Post: June 20th, 2007, 01:16 PM
