Results 1 to 10 of 19
Thread: some questions on calc.vet
    Jul 2015
    Default some questions on calc.vet
    Ive been doing calc.vet and have come across a few questions...
    for reference, this is a stock cubic inch ls1, trickflow 215 cnc heads, vengeance vrx5 camshaft (236/238 .601/,605 113 LSA), vengeance ported FAST90 intake/90mm TB combo, SLP lid, stock 78mm MAF-descreened, kooks 1 7/8 LT headers and 3" Y pipe fitted down to the stock Z28 muffler. I'm also running at roughly 3300 ish elevation.
    1. What impact on tuning is the descreened MAF creating?
    2. I'm also running a cutout between the stock exhaust and the kooks Y pipe and tuning with it closed. my logic is that the reduction in restriction with it open will cause a leaner condition but will still follow the same basic VE table form, so I may want to set WOT AFR at something slightly rich like 12.5:1 (and obviously double check open cutout AFR values once I have a smooth AFR reading under WOT). am I thinking correctly here?
    2. my LTFT have been reset a couple times and thus far the LTFT avg pid logs -1.6 and -2.3. What would cause one bank to have nearly double the LTFT correction percentage? is this normal or should I be looking for a collapsed lifter etc... creating an unequal airflow?
    3. My VE map corrections are creating a handful of spikes.. this is an example.
    Map before: Click image for larger version.
    Map After : Click image for larger version.
    Is this normal and/or what actions cause these? i.e. blipping the throttle, etc.
    4. Ive only primarily corrected/logged light throttle cruising, interstate driving, essentially avoiding PE mode due to an overly rich condition as I have killed one wideband sensor due to a 9:1 initial WOT AFR. this is why the map above shows an incomplete under 70 kpa, above 3000 portion of the map. I did do a few 100% full rpm range corrections with the old sensor before it went kaput and have gotten the AFR to run in the 12's up to about 4800 rpm, where it drops into the 11.5-12.0 range up to 6800.
    If I find the maf frequency where it starts to drop into the 11's and decrease the g/s airflow above that point by a percentage or two then blending, am I thinking correctly in terms of how to address this? Joecar, you have answered this on another thread for me.. I wanted to make sure I'm understanding what I'm doing rather than follow without understanding.
    Further, Am I correct in thinking also that since the ve table is disabled per the tutorial above 400 rpm that the computer is running entirely by MAF frequency at WOT right now and then also by fuel trims via narrowband o2 in non-pe enriched mode? Meaning I can manually get WOT in the 12.5ish ballpark through manual MAF correction then let selben fine tune it?
    Lastly, I'm to the point where the cruising / light throttle portion of the map is doing nothing but creating a moderately cratered surface on the map that I then go smooth out. the area I'm talking about is in the second above photo in the below 65 kpa/ below 3500 range. at this point, how do I know when i'm essentially done tuning that part?
    Thank you in advance for any help on these!
    Quote Originally Posted by estringer View Post
    Did you start from the stock tune...?
    On some vehicles, it makes no difference;
    on others it causes the MAF sensor to not see the airflow properly...
    the screen is an airflow straightener...
    removing the screen allows swirling (turbulent) air to go past the MAF sensor causing it to read incorrectly
    ( the airflow could be tumbling or bunched up on one side ).
    Make 2 tunes and compare.
    1% or 2% difference between banks is acceptable.
    Valvetrain problem (collapsed lifter) will cause a larger split.
    Is this from VE being corrected from the wideband (of so, is MAF disabled (DTC present)...?), or is this from VE being calculated from MAF...?
    Take a look at the 2D view of the corrected VE table, it indicates which cells were edited (i.e. these cells were "hit")...
    then bring the un-hit surrounding cells to the same level
    BUT: flatten out any tall spikes (positive or negative going spikes);
    use only minimal smoothing
    ( if you smooth something and it comes back, leave it )
    drive with smooth/progressive/slow throttle movements
    ( make sure you applied the transient filter )
    Also, are you using LTFT/wideband combination (SELBEN) or wideband only...?
    When you get this area of the VE corrected (so the BEN is at 1.00 +/-0.02), then by eyeball/hand extrapolate-extend (mimic the trend of) the known hit VE to the un-hit VE... this gives you a better starting point, take a log of a single pull to 4500 rpm at high throttle and look at the BEN.
    Yes, if the MAF is the contributor, and in some frequency range you see wideband indicate richer than commanded, then you would reduce the MAF in that frequency range...
    but keep in mind about the airflow straightener, it might cause low speed air to skew the MAF, or high speed air to skew it, or some combination;
    the PCM filters/smooths the MAF reading, but the correctness of the resulting MAF reading very much dependsthe MAF sensor seeing the airflow correctly.
    Yes, correct... disabled VE means that MAF is used exclusively.
    Yes, you can do that (keeping in mind that SELBEN selects either LTFT or wideband depending on the current operating condition... so you have to drive such that the wideband is selected).
    Drive using minimal throttle movement (i.e. keep throttle pedal as constant as you can, don't move it a lot).
    When you smooth, manually bring un-hit cells to same level/trend of hit cells (flatten spikes to this same level).
    When you get it right you will see very little change.
    No worries.
    Mar 2009
    When I smooth out spikes, I do so in a linear manner. My resulting VE map is never as pretty looking as the stock one. How are the cool guys making smooth, pretty looking maps?
    They must be hightlighting sections and hitting the smooth button several times.
    Generally, long tube headers will cause the VE table to have a few ripples at various rpm's (if you smooth them out, they come back on the next log).
    Mar 2009
    Consistently in the same spot? I remember on a 4 cylinder I had a tough time tuning it because of all the MAP spikes. I ended up putting a MIG welder tip in the vacuum line to the sensor and it only made it less bad. That motor had a header as well.
    Jul 2015
    Thanks Joecar… I’ve replied to your questions below. Im really unsure of how to proceed at this point.. ive added exactly what im doing below in hopes you can point me in the right direction
    I did not start from a stock tune, however I did paste in the stock MAF table from a 98 camaro, then also a stock VE and spark table from a ’02 zo6 I believe. Everything else in the tune I have gone through and compared to a stock tune so that there arent any variables im unaware of. Anything else that was different was my own doing and are things like fan on/off temperatures, cold engine protection, etc.
    I am following the calc.vet tutorial with no deviations.. so I think that would mean the VE is disabled and being calculated from MAF and ltft/wideband feedback?
    Okay, ive started to do this now. I was incorrectly working before, attempting to blend the VE table new/old values together. Thus far im one good log in on making adjustments via raising the unhit areas of the VE table to match other raised areas of the table. Im not entirely sure im doing what I should as im not sure what form the VE table should look like for this type of build but im giving it a go.
    A thought that I had…. If the VE table is disabled above 400 rpm (thus it has no effect on the engine operation right now)…. Would I not be better off by applying the new values without doing any smoothing at ALL for several logs? Then any spikes may show a proper trend? I could be entirely off my rocker here, this is my first tuning experience of any kind so my learning curve is pretty rough. I don’t know how many logs I should have to take to get a VE table figured. Im just thinking that if the VE table is disabled there is no point in smoothing it until I have enough raw data to show the form of the table.
    That said, here is where im unsure of how to proceed! Here is a screenshot of my last log’s cell count. I will also attatch my log at the bottom. Attachment 21484 I did about everything I could to populate the entire map, and now I’m unsure of how to really proceed… im operating on the understanding that PE mode is best tuned at only WOT, and not part throttle, so I don’t know how to hit any other areas of the VE table as the values that are left open here I cant hit without entering PE mode. I used braking under throttle, full throttle pulls(pe at WOT only), and anything I could think of to have a complete map of data. I have the PE mode enabled exactly as per the example given in the tutorial. Now I feel like I could go out at do more logs, but I don’t know how I will be gaining anything other that what I have. Am I missing something fundamental in understanding how this works?
    I am using SELBEN as per the tutorial for MAF correction.. paste/multiply with labels. However I am beginning to manually change the MAF values by percentage increase/decrease by referencing MAF frequency to wideband readings taken at WOT… and adjusting the maf frequency where the car begins to run rich as ive made 8-10 logs now (45 mins to 1.5 hours each) and im still running rich at WOT even after the maf has been corrected by SELBEN several times now. Ive only done this when my LTFT AVG has been between 0 to -4 ish as I understand it will add any positive LTFT AVG to PE mode as a safety. Am I doing this wrong?
    this has me confused. If the VE is disabled, how does the BEN reflect the VE table? Doesn’t it reflect only the MAF correction, then calculates the proper VE table? If I understand you correctly I should watch SELBEN factor on a WOT pull to 4500…. The goal is to have it within .02 of 1.00. but im unsure of what this would be telling me other than that the MAF is where it should be
    I must not understand something fundamental in this process.. I am running with ve disabled above 400 rpm so I am assuming that the MAF can only be the contributor.
    What do I look for in the logs to determine if this is a problem?
    Jul 2015
    Calvet9.efi
    Attatched log
    Yes, do it like that, take successive logs and watch the VE build itself up.
    That said, here is where im unsure of how to proceed! Here is a screenshot of my last log’s cell count. I will also attatch my log at the bottom. I did about everything I could to populate the entire map, and now I’m unsure of how to really proceed… im operating on the understanding that PE mode is best tuned at only WOT, and not part throttle, so I don’t know how to hit any other areas of the VE table as the values that are left open here I cant hit without entering PE mode. I used braking under throttle, full throttle pulls(pe at WOT only), and anything I could think of to have a complete map of data. I have the PE mode enabled exactly as per the example given in the tutorial. Now I feel like I could go out at do more logs, but I don’t know how I will be gaining anything other that what I have. Am I missing something fundamental in understanding how this works?
    Tune part throttle (low-medium load) first, then observe the trend in VE and MAF tables and extrapolate that trend to the upper portions of VE and MAF... and then go and do PE/WOT.
    A few more logs (just a few) will fill in the VE gaps (the biggest problem is holding in any one cell for a sufficient number of cell hits, the vehicle just runs away...).
    the n button shows the hit counts for each cell;
    to see the average value in each cell, click the x-bar button.
    Jul 2015
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. Need some help with Calc VET
    By HellKnightHicks in forum Gen III V8 Specific
    Last Post: February 21st, 2019, 09:57 AM
  3. Replies: 4
    Last Post: September 11th, 2013, 03:38 AM
  4. Calc vet ???
    By Chuck L. in forum Gen III V8 Specific
    Last Post: September 8th, 2011, 02:12 PM
  5. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 02:20 PM
