Results 1 to 3 of 3
Thread: question on OL/MAF
    Oct 2005
    Default question on OL/MAF
    When configuring LS1A for OL/MAF what determines what is controlling commanded fuel, B3605 or B5001?
    B0120=0
    B3801=disabled
    B4205=140c
    97 Vette 6spd, CamMotion Titan2 LS1 cam, TSP 5.3 StageII heads, Vararam intake, Z06 manifold, ARH headers/cats, Z06 catback, Monster Stage2 clutch, 04 Z06 pcv, new style knock sensor(late98 to 04).
    Using FlashScan V1 with NGK-AFX Wide band
    Jul 2003
    B3605 and B3618 (the richer of both)
    B5001 is MAF Curve will control actual fueling and not commanded AFR.
    MAF B5001 and VE B0101 are tables which feed into the cylinder airmass calculation;
    OLFA B3605 and PE B3618 are commanded fuel tables, these are applied on top of cylinder airmass;
    at any instant, regardless of MAF/VE, the commanded fueling comes from the richest of the active fuel tables at that instant (i.e. on a cell-by-cell basis)...
    in OL, B3605 is active;
    in PE, B3618 is active (regardless of OL);
    if PE is not active, then B3605 will be the active table;
    if PE is active, then the richer of B3605 and B3618 will be the commanded fuel;
    if engine/piston protection modes are active, then the richer of B3605, B3618, B3603, B3659 will be active;
    if COTP is active, then while we can't see its table, we know COTP commands EQR 1.25, this will be commanded fueling if it is richer than the currently active tables.
    So B5001 determines the cylinder airmass (log GM.CYLAIR_DMA), and B3605 determines commanded fueling (if PE is not active).
    The other trick GM built into their code is this:
    if the richest of the active tables is leaner than stoich, then stoich will be commanded.
  1. ol maf tune or ve maf open loop and lambda question
    By 400ss in forum Gen III V8 Specific
    Last Post: February 1st, 2015, 07:12 AM
  2. need help with MAF tube question
    By wwaveforms in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 20th, 2012, 06:27 AM
  3. MAF question?
    By whackem04 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 17th, 2010, 10:54 AM
  4. MAF removal question
    By s10mods in forum Gen III V8 Specific
    Last Post: October 5th, 2007, 02:04 AM
  5. MAF-less question
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: June 23rd, 2006, 01:34 AM
