Results 1 to 8 of 8
Thread: V8 Scan - Calculated Ben factor
    Default V8 Scan - Calculated Ben factor
    Have the following setup for the aem analog ad4 port, but the factor never changes from 1. Any idea's?
    [AEM]
    AD4LAMBDA="AD4 AEM Lambda",lambda,1
    BENAEMAD4="AEM BEN",factor,3
    AD4AFR="AD4 AEM AFR",AFR,1
    [AEM.AD4LAMBDA]
    0=|-- AEM.AEMAD4L
    1=|return pid("EXT.AD4")*0.1621+0.4990
    [AEM.BENAEMAD4]
    0=|-- AEM.BEN
    1=|return pid("AEM.AD4LAMBDA")/pid("ECM.EQ_RAT")
    [AEM.AD4AFR]
    0=|-- AEM.AEMAD4AFR
    1=|return pid("AD4")*2.3750+7.3125
    Log file attached
    E38_T436.pld
    Sep 2003
    I have a semi-colon at the end of each entry.
    [AEM.AD4AFR]
    0=|-- AEM.AEMAD4AFR
    1=|return pid("AD4")*2.3750+7.3125;
    [AEM.BENAEMAD4]
    0=|-- AEM.BEN
    You mean the BEN is always 1...?
    Can you attach a log file.
    log file is attached already Joe.
    Yes the ben is always 1.
    I have another problem where the log always stops at 478kb in size with a error. Not sure if it's the v2 causing it, but it has the same error & log files are always the same size. Doesnt seem to matter what version or usb port i use.
    It's been on on-going thing for a long time, as even with the v7 logger i get a small freeze wile logging sometimes before it continues.
    This is the error i get while logging with v8 too.
    fixed the graph issue. it was only showing 1 because the graph precision needed to be changed to 3.
    i also un-installed, cleared all the installed software. now the ben is working in the maps section too, Go figure.
    will see if that also resolves the connection drop out
    Ah, I see it.
    Where do you change the precision...?
    chart properties. click on the cell window. then change value precision.
    Might be a question for Ross/Paul as to how to set that default amount to match the pid value
  1. Replies: 30
    Last Post: April 8th, 2017, 10:59 AM
  2. Ben Factor Question
    By EVI in forum E37, E38 & E67 PFI ECM's
    Last Post: March 17th, 2010, 11:01 PM
  3. Auto VE Ben Factor
    By shane in forum Gen IV V8 Specific
    Last Post: June 20th, 2008, 11:34 AM
  4. Logging BEN factor with March 20th Beta?
    By Goldfinger911 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 06:03 PM
  5. Math Wizzards - BEN Factor IAT correction
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: July 29th, 2005, 02:56 PM
