Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: $0537 lly duramax
    Sep 2017
    It wouldn't lock because my airbag sensor went right just wanted to double check before I started looking for a new ecm
    Nov 2005
    Quote Originally Posted by Duramax23 View Post
    If you had a communications error because of something interferring on the can bus, or because something was mechanically unsound you would not be getting an error code that detailed the ECM was locked.
    The error code list isn't generic - there are 41 very detailed pages of error codes breaking down the errors received.
    Cindy
    Apr 2006
    We have ecms that i can load your tuning onto and send it. Call for the costs. Most likely your ecm will be a repairable core but i can put it on the bench harness and see what is up with it.
    Sep 2017
    Could it be a software update issue if my trucks software is out of date or if the efi live software is out of date
    Nov 2005
    You'd have had a different error if your software was out of date. $0537 is controller is locked with custom key.
    Cindy
    Sent from my iPad using Tapatalk
  1. V8 virtual Dashboard for LLY Duramax
    By rmdiesel91 in forum Diesel
    Last Post: December 19th, 2014, 08:56 AM
  2. Need help scanning my LLY duramax with V8
    By durtydiesel06 in forum Diesel
    Last Post: July 1st, 2014, 06:37 AM
  3. DURAMAX lly Boost tables
    By Banshee1973 in forum Duramax LLY
    Last Post: March 18th, 2010, 03:35 PM
  4. 06' Duramax w/LLY motor can I??
    By Redline Motorsports in forum Duramax LLY
    Last Post: March 15th, 2006, 04:10 PM
