Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Need help with calibration E80 camaro.
    Junior Member Madcat's Avatar
    May 2017
    Default Need help with calibration E80 camaro.
    Hello all tuners all cuntry
    I'm from Russia, we have only 2.0 LTG engines
    in stock 238Hp for RF (For usa it is 275HP)
    in stock 400Nm
    today go on dyno
    216Hp on wheels 350Nm after new calibrations
    whats wrong?
    i' dasapointed :(
    exhaust system 89->76 without catalityc
    Cold intake installed
    Hi Madcat, welcome.
    Do you have any log files (captured using the EFILive V7.5 scantool)...?
    May 2017
    Hi Madcat, welcome.
    Thank you Joe!
    No, i can make now. what you want to see?
    efilive is new prog for me, but i buy it for new ecu acdelco.
    what tables or pid i need to add in 7.5 that you can see right info.
    Log these pids:
    SAE.RPM
    SAE.MAP
    SAE.MAF
    SAE.IAT
    SAE.ECT
    SAE.BARO
    SAE.LONGFT1
    SAE.SHRTFT1
    SAE.LAMBDA
    SAE.SPARKADV
    GM.KR
    GM.KNKRET
    GM.MAFFREQ2
    GM.MFTOTAL
    GM.ETCTP
    GM.HO2S11
    GM.INJPWB1
    CALC.INJDCB1
    CALC.CYLAIR
    Madcat,
    so your engine is normally aspirated (no turbo, no supercharger)...?
    do you know the octane rating of your fuel...?
    do you know the alcohol content % of your fuel...?
    May 2017
    Engine 2.0 LTG single turbo
    Octaine( i know) 100 but i think in real 98.
    alcohol dont know...
    Now i go to log pids.
    ok, single turbo, thanks.
    May 2017
    I check pids. 7.5 not supported camaroe80. i add all pids, but it not work. maybe 1 or 2 pid. but in v8 pid is work well. can i record it in v8 and send it?
    Yes, please post your V8 log.
    May 2017
    Hello again!
    I try and try and get new results
    306 Hp and 470Nm
    and now question who can do boost more than 1.6? i try and try, but not...
  1. E80 VATS Patch
    By jrz in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 13th, 2017, 01:01 PM
  2. E80 L4 SIDI how is boost increased what tables to change? 2016 camaro 2.0 turbo.
    By david imgrund in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 12th, 2017, 01:11 PM
  3. E80 L4 sidi flex fuel pin location 2016 camaro
    Last Post: March 10th, 2017, 02:46 AM
  4. 2000 Truck calibration to 2000 Camaro calibration
    By redtacoma31 in forum Gen III V8 Specific
    Last Post: January 7th, 2017, 08:48 AM
  5. 2012 Camaro SS gear swap, speedo calibration?
    By slowhawk in forum E37, E38 & E67 PFI ECM's
    Last Post: December 29th, 2012, 03:04 AM
