Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Need help with calibration E80 camaro.
  1. #21
    Do you have new dyno graphs...?
  2. #22
    Junior Member Madcat's Avatar
    May 2017
    No need dyno because 0-100: 6.5 sec. air 230g/sec, pressure 1 bar. All what i edit: spark, boost, fuel - not effect. I edit ve tables, coffs, torque, all is not effect. You see my file.
    I go in dyno now.
    I read forum hptuners, they have a same problems. Edit files and not change anything.
    I need new file for dyno now, but i hanen
  3. #23
    I'm looking thru your files... (I am not familiar with the 4-cyl LTG engine).
  4. #24
    May 2017
    I check all connections. Find some toubles. And have p0299. I think actuator need to be checked.
    I write when all is good with new logs.
    Today go on gyno, but trouble code and underboost not to do good graphs
  5. #25
    May 2017
    Hello! thank you for help
    I try calibrations on new turbo and old turbo. And have some logs.
    Can you looking it?
    New turbo is 335 Hp and 410 Nm(302 lb/ft) On 4000rpm throttle is close. I cant understand why. I thought that torque tables for that and I do it upper, ~600Nm
    I install stock turbo and torque like a new turbo in peak(405-410 Nm (302lbft). I cant understand what is going on))
    I want to send you my files. Can you look it? How I can send you my calibrations?
    here Is logs
    Cam_stend is new turbo
    other in stock turbo on road
  6. #26
    Do you see any DTC appear when throttle closes...?
    You may have to adjust the sanity test tables in the Engine Diagnostic section.
  7. #27
    May 2017
    I off electronic baypass and install vacuum. And off many dtc. How i can send you my file?
  1. E80 VATS Patch
    By jrz in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 13th, 2017, 01:01 PM
  2. E80 L4 SIDI how is boost increased what tables to change? 2016 camaro 2.0 turbo.
    By david imgrund in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 12th, 2017, 01:11 PM
  3. E80 L4 sidi flex fuel pin location 2016 camaro
    Last Post: March 10th, 2017, 02:46 AM
  4. 2000 Truck calibration to 2000 Camaro calibration
    By redtacoma31 in forum Gen III V8 Specific
    Last Post: January 7th, 2017, 08:48 AM
  5. 2012 Camaro SS gear swap, speedo calibration?
    By slowhawk in forum E37, E38 & E67 PFI ECM's
    Last Post: December 29th, 2012, 03:04 AM
