Results 21 to 30 of 49
Thread: Cummins Fueling Status and Timins Status
  1. #21
    Jan 2016
    Here is fueling states list I have for those interested. It is old FYI
    https://mega.nz/file/Uy4y0QwR#WYLVo3...8VB2mO8O8gzAW8
  2. #22
    Jan 2020
    Quote Originally Posted by Orange Stroker View Post
    This is def what I needed to see. I recently got more fuel control state data out of it on the dyno and the previous list only went up so far. This gave me data about state 86 and a more extensive list. Thanks for taking your time to get that to me!
  3. #23
    Mar 2013
    i have same issue also, problem is that efi never mapped the torque management tables. i have figured out they are related to the speed inputs. the ecm thinks it's destroying the drive train so it's trying to save itself. i reallly wish they would add this to program or if someone else could find and map this it would be awesome.
  4. #24
    Jun 2021
    Has anyone every figured out this code 45? I keep hitting it.
  5. #25
    Jan 2016
    Post your file.
  6. #26
    Jun 2021
    They are maxed. Tried keeping it under 126mm3 because count 45 limits at 126mm3 at 3500. I need a .cax file but no one wants to share hex files so I can look through it. Just doing this as a hobby and everyone makes it’s so difficult.
  7. #27
    Jun 2021
    Quote Originally Posted by justinp View Post
    There is a guy out there that has but won’t let it up.
  8. #28
    Sep 2018
    Bumping this up. Has any resolution been found for this? I'm finding that on the logs from my OS that the transition from governor status 7 to governor status 45 is tied directly to crossing any duration command above 1600uS. This causes a plateau on the fuel command, a "derate', that would otherwise continued on a nice upward slope. I will post some screenshots when I can get back to them.
    Sent from my motorola one 5G using Tapatalk
  9. #29
    Sep 2018
Name:	Screenshot 2022-11-22 094708.png
    I found another log that appears to be 1500uS. I am going to get another log today as this one is over a year old.
  10. #30
    Aug 2019
    You will not be able to reach full fuel in a stand-alone setup without help outside of EFILive. I have posted about it. There are several Limiters not provided in EFILive. You can use Hp Tuners for a single tune or find someone to write you up a CAX file.
  1. Status: Unkown
    By Hutch741 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 20th, 2018, 02:03 PM
  2. fueling status???
    By relentless addiction in forum General (Petrol, Gas, Ethanol)
    Last Post: May 9th, 2012, 11:23 AM
  3. TAQCables - Status
    By TAQuickness in forum Lounge
    Last Post: January 18th, 2011, 11:26 PM
  4. V2 status
    By minytrker in forum FlashScan V2
    Last Post: November 19th, 2006, 01:21 PM
  5. Order status
    Last Post: February 12th, 2005, 01:36 PM
