Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
Thread: Cummins Fueling Status and Timins Status
  1. #31
    Oct 2012
    Quote Originally Posted by Twistedshafts View Post
    You will not be able to reach full fuel in a stand-alone setup without help outside of EFILive. I have posted about it. There are several Limiters not provided in EFILive. You can use Hp Tuners for a single tune or find someone to write you up a CAX file.
    OK, I am listening. Thank you for the information.
    biggy and I have been discussing this exact topic on another forum as we are both having this issue.
    So.. the issue that exists cannot be overcome with what is currently mapped in EFILive, as all of the limiters are not mapped in EFILive... Got it. I can either obtain the files necessary for CalTerm to find the limiters and then create a cax file.
    However, you're making it sound like the necessary limiters are mapped in HPTuner. I hate HPTuner. But, if the limiters are mapped in HPTuner, a single file could be modified with the limiter addressed, flashed onto the ECM, and then the file read out with EFILive, modified further as desired and flashed back on. With the limiters being addressed in the background, in the areas unable to be edited by EFILive, the issue should be resolved. Is this correct?
  2. #32
    Sep 2018
    Default Interesting
    Sorry for the late reply, but thank you for the response. Is this to say that HP does have these limiters exposed? Even with a CAX, is this due to the lacking TIPM comm? I suppose one could tune around it.Click image for larger version.
Name:	Screenshot 2023-06-15 025728.png
  3. #33
    Member arinkuddy's Avatar
    May 2014
    Quote Originally Posted by biggy238 View Post
    You can download and look at tunes in HP Tuners just like EFILive. I have done this exact same thing. I will use HP Tuners to make a change to the base file then upload to ECM, read out, reapply changes using compare tool in EFILive then upload again. Tedious for sure.
  4. #34
    Sep 2018
    Quote Originally Posted by arinkuddy View Post
    I may try this. I retooled a manual file to match my auto file and it still has the same status code derate under heavy throttle.
    Once it hits 115mm3 fuel position, it changes from an exponential climb, noses over and eventually hits 130mm3 anyway. More of a nuisance than anything at this point.
    Sent from my motorola one 5G using Tapatalk
  5. #35
    Aug 2019
    HP Tuners is actually very awesome. They do provide all the tables to get past the TTVA for FMVB. There is also another limiter not in EFI live that doesn't allow fueling past 3,800. You can disable the PID control under rpm limiters. If you do this you will have full MM3 to whatever you want but ECM will no longer control the FCA and rail pressure drops. It does not work correctly. Pid must stay enabled for proper FCA control through the entire RPM curve. Things you would think EFI Live would have added into the software so people everywhere could use these trucks to their full capabilities. Not just people you can build CAX files. I spend a lot of money with EFI Live but it is lacking and frustrating.
  6. #36
    Aug 2019
Name:	Hp Tuners High Speed Governor.png
    Here is a limiter not provided. High speed governor will pull fuel.
  7. #37
    Sep 2018
    Can I load an HP base file into an ECM with the CSP5 patch, or will I need to flash back to stock first?
    I assume I need to configure a stock file in HP, flash it, read out with EFI, and then convert to CSP5.
    Photo of the nose-over in fuel position
    I agree, I'm not the most EFI fluent, but I've seen several things that seem lacking. I guess a 20 year old platform isn't relevant for support.
  8. #38
    Aug 2019
    I am currently working on this problem and hope to have a solution in the near future. I may put the file into BIN format and then convert it back to CSP5 so the limiters are gone. You can change all the limiters in Hp Tuners and flash it in. Read it out with EFI Live and convert it over. Make your changes and flash it back in.
  9. #39
    Sep 2018
    Excellent. Let me know if there is anything I can do to help. I'm checking to see if I have an HP credit left now.
  10. #40
    May 2014
    pretty sure this limiter is in EFILive called out under engine protection
  1. Status: Unkown
    By Hutch741 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 20th, 2018, 02:03 PM
  2. fueling status???
    By relentless addiction in forum General (Petrol, Gas, Ethanol)
    Last Post: May 9th, 2012, 11:23 AM
  3. TAQCables - Status
    By TAQuickness in forum Lounge
    Last Post: January 18th, 2011, 11:26 PM
  4. V2 status
    By minytrker in forum FlashScan V2
    Last Post: November 19th, 2006, 01:21 PM
  5. Order status
    Last Post: February 12th, 2005, 01:36 PM
