Thread: E67 to another E67
    Sep 2017
    Question E67 to another E67
    Hi guys, my question is is it possible to make a full backup of #1 E67 ECM and then back it up to another #2 E67 ECM (used from another car)? Will the VATS cause problem?
    I want to have a spare ECM, just in case I mess up the original one and I found one pretty cheap.
    Thank You.
    Sep 2017
    Nobody knows?
    Often tuned ECUs will not pass the test. Having an original back up, ready to plug in would be a great solution to this.
    It should work if the year/model of the spare ECM is close/same as your main ECM.
    If you full flash the same tune onto the spare ECM, VATS should not cause any problem, AFAIK.
    Sep 2017
    Thank you, that would require 2 VIN licenses? Because I read from one VIN and transfer to another?
    A
    No, it will only require 1 VIN license if you intend to keep 1 of the ECMs factory. Reading/logging does not use a license, only when you flash a controller.
    Note, you will need to obtain a spare ECM that has has the proper OS loaded via TIS/GM SPS. You cannot buy a random junkyard or even a brand new controller and Full Flash it with EFILive to have a spare ECM. If a new ECM, you need to ensure it is the correct part number and has been flashed for your vehicle with TIS/SPS. If a used controller, you need to make sure the OS on the controller is compatible with your vehicles' OS before attempting to flash with TIS/SPS.
    +1 flashing requires a license, reading does not.
  1. Upgrading Os on E67
    By Naf in forum E37, E38 & E67 PFI ECM's
    Last Post: May 2nd, 2016, 07:40 PM
  2. E67 IAT's
    By b4pjs in forum Gen III V8 Specific
    Last Post: August 19th, 2015, 09:55 AM
  3. tuning e67
    By MECHAN12 in forum E37, E38 & E67 PFI ECM's
    Last Post: May 2nd, 2011, 03:24 AM
  4. E67 cts-v
    By jbehe in forum E37, E38 & E67 PFI ECM's
    Last Post: May 24th, 2009, 11:59 PM
  5. reflashing the e67
    By nycblazer in forum Gen IV V8 Specific
    Last Post: April 17th, 2008, 11:10 AM
