Results 1 to 10 of 19
Thread: Sep 2017, Release Candidate 2
    Default Sep 2017, Release Candidate 2
    Download EFILive V7.5
    Download EFILive V8
    Release Candidate Version
    This RC2 version may now be used by all EFILive tuners and their customers in production environments.
    Barring any serious problems being discovered, this RC2 will become the official public download.
    If you do discover a problem with this RC2 software, please report it to EFILive as soon as possible by posting in this thread or by emailing support@efilive.com or by logging a support request in the helpdesk.
    Release Notes:
    PLEASE read the "Important Changes" section at the top of the "What's New" document.
    The way EFILive reports/uses software version numbers has changed (new in RC2).
    The way EFILive reports and manages out of range calibrations has changed (new in RC1).
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.11 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.6 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.124 (Sep 17, 2017) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    Thanks Paul.
    May 2010
    Thanks Paul
    Is there any way to automatically put the VIN number in the Log file name in V7.5 as in the previous updates ?
    I tried to find this option but could not
    EFILive Tuner
    Thanks Paul
    Yes, just use the tag <vin> in the filename template.
    Jul 2003
    This got smaller!
    This got smaller!
    What got smaller?
    Under V7 scantool Properties->Folders->Tune Files, for Subfolder template, in the Tag drop down is it possible/easy to include <vin> and <cn> (i.e. consistent with scan file subfolder template)...?
    ( and it would be real handy if the V7 scantool could also have a property (under Folders) to specify the calc pids txt file )
    Agreed, I've often thought that would be nice for trying out files from other users (I'll see what I can do).
    Dec 2005
    I keep getting decompression error #2026 on both files.
    Downloaded multiple times, same thing.
    Disabled real time scan on McAfee same thing.
    Any ideas?
    Thx
  1. Sep 2017, Release Candidate 1
    Last Post: September 16th, 2017, 04:28 PM
  2. Sep 2015: EFILive Public Pre-Release
    Last Post: October 28th, 2015, 09:24 PM
  3. Known issues with Sep 12, 2014 release of the EFILive software and firmware.
    Last Post: September 26th, 2014, 04:43 AM
  4. Release Candidate 10, Mar 11, 2012
    Last Post: March 28th, 2012, 12:52 AM
