Results 1 to 3 of 3
Thread: Fine tuning MAFT and VE tables
    Jan 2012
    Default Fine tuning MAFT and VE tables
    I know that the tutorial states fixing tables in a single log. Can you continue to fix the tables (Fine tune)? If you redo the process over and over and continue to multiple with labels will the tables fine tune?
    I know that I have multiplied 1s into the new tables and the numbers changed slightly. Why is this? 1x80=80. Why did my cells change? The reason I am asking is some cells seem hard to log.
    Calc.VET:
    You can continue to to fine tune... but pay attention to how much the MAF is changing the VE; after the first iteration, if there's too much change then something's not right.
    Calc.MAFT:
    same thing, but swap words MAF and VE in above sentence.
    As always: use common sense, if something is not right then shout out.
    Jan 2014
    as I 'fine tune' things I don't take all of the logs suggestion. At first I will paste and multiply. As I get closer to where I want to be I will paste and multiply (50%) or so.
    Me being slightly OCD I try to get most of the cruise cells to slightly lean on the VE, and all the power cells slight rich on the VE- since they are never perfect 1.000 correction.
  1. Calc.MAFT and odd results
    By tenpaiyomi in forum Gen III V8 Specific
    Last Post: May 5th, 2016, 01:35 AM
  2. Replies: 15
    Last Post: January 19th, 2016, 09:33 AM
  3. trying to do a little fine tuning with no wideband
    By loganlewis in forum Gen III V8 Specific
    Last Post: October 25th, 2012, 09:04 AM
  4. Need a little help gettin started on COS3 fine tuning. Please
    By nonnieselman in forum Custom Operating Systems
    Last Post: June 11th, 2007, 05:47 PM
  5. Fine tuning AFR in PE
    By 12sec.5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 25th, 2006, 03:08 PM
