Results 1 to 2 of 2
Thread: Fuel Pressure Tables And Dual Fuelers
    Jan 2016
    Default Fuel Pressure Tables And Dual Fuelers
    Hello,
    I am currently getting 12k rail pressure at idle on basically a stock tune with ats dual fuelers. I was curious, when you have dual fuelers do I need to cut this tables in half to get the desired idle rail pressure?
    Ats dual fuelers with controller box (all new)
    duramax 2nd pump, new and duramax fca (does this need to be cummins?)
    lift pump pressure at the engine is 8psi (12psi throws p0088 rail pressure too high)
    white smoke from tailpipe
    rough idle, lots of injector knock
    Thanks in advance
    Dec 2017
    Did you ever figure this out?
  1. dual fuel tanks
    By Cwalt50 in forum Duramax LLY
    Last Post: November 25th, 2016, 04:45 PM
  2. Fuel Pressure Tables
    By FUBAR in forum Cummins 5.9L
    Last Post: February 25th, 2012, 04:29 PM
  3. can I log fuel pressure with my glowShift fuel pressure gauge?
    By ryans1000 in forum External A/D inputs
    Last Post: August 16th, 2011, 01:35 AM
  4. Fuel Pressure Question - Missing Tables?
    By Jack_the_Diesel_Killer in forum General (Diesel)
    Last Post: May 16th, 2009, 05:24 AM
  5. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
