Results 1 to 9 of 9
Thread: 3 bar map sensor - 411 PCM
    Member badls1's Avatar
    Dec 2009
    Default 3 bar map sensor - 411 PCM
    I have been struggling to find a 3 bar map sensor that works with efilive via a 411 ls1 computer.
    Last year i tried a old style delphi 3 bar map and had nothing but issues. There was a blank area in the tune that i could not change and would go real lean every pass. Car drove low rpm fine and was reading boost over 20psi. Swapped back to my 2 bar map/tune and the car would run/pull fine.
    I have been running all year 25+psi on my 2 bar and really need to get this figured out.
    Which 3 bar map do you guys recommend/have experience with at high boost levels on the 411 pcm?
    1989 Notch l Forged 5.3L l PT91.5 l th400
    SBE 4.8L l S475 l th400 8.62@156 (old setup)
    Dec 2009
    Anyone run 3 bar making 25+ psi?
    Lifetime Member wesam's Avatar
    May 2010
    I'm runing ZR1 3 bar map sensor but the problem the scaner can't log morr than 255 kpa which equal to 22.5 psi
    so after that you can not correct the boost VE table
    EFILive Tuner
    Aug 2013
    Quote Originally Posted by wesam View Post
    255kpa is actually NOT equal to 37psi.
    Last edited by statesman; October 14th, 2017 at 11:37 PM. Reason: incorrect calculation
    May 2010
    255 kpa at see level equal 22.5 psi
    255 -101 =154 kpa
    EFILive Tuner
    Aug 2013
    Yes, you are correct. I work more with compressed gases than I do with boosted engines.... my mistake, and my previous post has been edited.
    Dec 2009
    Thanks. So it sounds like the zr1 is just a 2.5 bar like my dpe.
    On some LS1 OS's there is a PID 'GM.MAPBOOST_DMA', that'll read above the SAE.MAP PID's limit of 255kPa.
    May 2010
    Thanks Paul I will check if its available in my car with COS5
    EFILive Tuner
  1. Updating 2 bar to 3 bar map sensor
    By badls1 in forum Gen III V8 Specific
    Last Post: November 2nd, 2015, 12:40 PM
  2. 98 PCM 2 bar map sensor
    By ddnspider in forum Gen III V8 Specific
    Last Post: June 23rd, 2014, 10:28 AM
  3. 3 Bar MAP sensor doesn't work with 3 Bar scaling!
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: April 27th, 2010, 05:21 PM
  4. 3 bar map sensor
    By Delco in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: March 5th, 2007, 07:18 PM
  5. 2 Bar Map Sensor?
    By caver in forum General (Petrol, Gas, Ethanol)
    Last Post: September 6th, 2005, 05:56 PM
