Results 1 to 10 of 11
Thread: E86A Not Recognized By EFILive
    Feb 2012
    Default E86A Not Recognized By EFILive
    EFILive will not recognize this E86A controller. According to the service# it is for a 2012 D-Max, just not sure why V8 will not recognize it. The below pics are the ecm tag, and OBD2 using V8. I manually selected the E86A tab. According to the tune file service number 12648344 is supported. Any help will be greatly appreciated.
Name:	Screenshot 2017-09-23 14.02.41.png
ID:	21534Click image for larger version.
    Sam
    Lifetime Member Road's Avatar
    Feb 2015
    Looks like it recognized it. Are you trying to read it?
    Feb 2012
    It did not recognize it. I had to manually select the controller. I know it can't be read with EFILive. V8 will not allow to flash, it says the controller is not an E86.
    Sent from my SM-G900V using Tapatalk
    Feb 2015
    It has odd OS too. I would make sure V2 firmware is up to date.
    Feb 2012
    Yes defiantly an odd OS. This is a new replacement ecm. The last E86B ecm I swapped out had a strange OS as well.
    Quote Originally Posted by 30 RUM View Post
    They ship from Bosch with some generic no run calibration and OS because they assume that every time GM will be connecting to TIS and flashing the correct OS/Cals in for the truck. V8 won't pick up the controller type because it must not respond with known messages with that program in the ECM.
    Feb 2012
    So is the only solution to flash it with tis first? Is there any way to force V8 to full flash over the OS in the ecm?
    Sam
    V8 cannot be forced to flash over an OS it is not familiar with, trust me this has saved many users needing to purchase new ECM's by not corrupting them if we allowed that.
    EFILive works around the logic that it will be tuning a running vehicle and therefore a standard release GM OS. A brand new off the shelf ECM will need to be initialised with TIS.
    Feb 2012
    Okay,
    Will do.
    I assume I should do the vats learn after the ecm is flashed with tis correct?
    Yeah that is the issue, additional set up needs to be done with TIS, injector flows, blah, blah. Pretty sure there is an option in TIS to do all this at the time of programming.
  1. flashscan not recognized
    By blazinblue in forum FlashScan V2
    Last Post: September 5th, 2009, 10:00 AM
  2. flashscan V2 not recognized
    By charlie b in forum FlashScan V2
    Last Post: August 23rd, 2009, 09:45 AM
  3. V2-device not recognized
    By zacksfoam in forum FlashScan V2
    Last Post: August 14th, 2009, 06:56 PM
  4. K Engine not recognized
    By Lennart in forum E37, E38 & E67 PFI ECM's
    Last Post: February 7th, 2008, 01:27 PM
