Results 1 to 9 of 9
Thread: E78 Fuel Tables
    Jan 2014
    Default E78 Fuel Tables
    Hello Guys,
    I would like to calibrate the fuel on a 1.4T with E78 controller. I would like to take off some fuel on specific rpms and load.
    Is any fuel table which (e.g. injection correct factor) which could do the job?
    Thanks!
    Can you post your tune file...
    Jan 2014
    Hello,
    Thanks for your reply.
    Here's the file.
    At what rpm and tp do you want to remove fuel (and why)...?
    Jan 2014
    we want at WOT from 5000 up to 6000 rpm because it is very heavy )AFR 10:1, but generally we are planning to change injectors and bigger turbo and they always need fine tuning, so we need to know how to do it
    OL fueling: see table B0148
    PE fueling: see table B3618
    both of those tables are already not adding much/any fuel...
    what do you see that makes you want to remove fuel...?
    You could mess with this injector correction table:
    B1219 injector correction by MAP
    Jan 2014
    Thanks for the quick reply. I think the B0148 is what i am looking for. It seems using this table i can add/remove fuel based on map and rpm. I will try that and give you some feedback.
    Is it possible to change the scalling of the table in case i want to do changes at higher boost?
    B0148 's axis ranges up to 180 kPa (i.e. 0.8 bar boost)... I would have to study the tune file to see if it's possible to scale on this table.
    Jan 2014
    Great, if we could do that it could be a great adittion.
  1. Too many tables are missing in E78
    By wesam in forum E78, E83, E84 PFI ECM's
    Last Post: May 11th, 2017, 04:27 PM
  2. E78 VVT Tables
    By a78turbo in forum E78, E83, E84 PFI ECM's
    Last Post: July 19th, 2016, 09:05 AM
  3. E78 VVT Tables
    By a78turbo in forum E39, E80, E82 & E92 SIDI ECM's
  4. Too many tables are missing in E78
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: April 20th, 2015, 04:40 PM
  5. Fuel Pressure Tables
    By FUBAR in forum Cummins 5.9L
    Last Post: February 25th, 2012, 04:29 PM
