Thread: vehicle says it is not licensed after being flashed several times?!
    Jan 2008
    Default vehicle says it is not licensed after being flashed several times?!
    Looking for info on why vehicle says it isn't licensed? Flashed several times on the dyno and now gives me the error that i need to license the controller.
    thanks,
    Brandon
    2000 RCSB silverado, stock 6.0 transplant, LS6 bumpstick, t76 turbo on meth tuned by me
    best ET 7.02 in the 1/8th
    Are you attempting to flash using V7 or V8 or V2 (in BBc mode)...?
    Which PCM/ECM...?
    Jan 2008
    I've tried both v7 and v8
    Sent from my SM-G930V using Tapatalk
    Jan 2008
    P59 PCM
    Quote Originally Posted by 02sierra4x4 View Post
    thanks,
    Brandon
    Hi Brandon,
    Could you please send the following files to me at paul@efilive.com
    A *.lbu license backup file from your FlashScan.
    A *.ctz file read from the controller after it started rejecting the VIN license.
    A *.htx trace file of an attempt to flash the controller after it started rejecting the VIN license.
    More info on how to generate/find the *.lbu and *.htx files:
    https://support.efilive.com/kb_artic...8552-EOAJ-5912
    https://support.efilive.com/kb_artic...9413-RPHL-6309
    Paul Blackmore
    Jan 2008
    Hi Brandon,
    Paul Blackmore
    Thank you will do!
  1. Flashed a 6.7 and now its dead. Help please!
    By Compcowboy in forum Cummins 6.7L
    Last Post: February 12th, 2016, 05:42 PM
  2. Replies: 1
    Last Post: December 29th, 2014, 12:28 PM
  3. Replies: 4
    Last Post: January 3rd, 2013, 08:15 PM
  4. Flashed RR and ECM won't boot
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 4th, 2011, 08:53 AM
  5. Replies: 4
    Last Post: September 10th, 2010, 01:38 PM
