Page 9 of 11 FirstFirst ... 7891011 LastLast
Results 81 to 90 of 101
Thread: CMC High RPM Fueling
  1. #81
    Jun 2011
    I second that les. It is very nice having the ability to scale the sensors on the cmb ecm. I have repurposed multiple of the factory sensors to do something different on competition trucks
  2. #82
    Dec 2013
    The newer stuff converts Counts to pressure. A little birdie told me that the CMC charge pressure tables are on the way as well.
  3. #83
    Quote Originally Posted by 2007 5.9 View Post
    Ross...while you are in there...can I ask for the "Boost Pressure, Voltage to Pressure Conversion" table be added to the CMC and maybe to the CMD/CME as well?
    Its table E3255 for the CMB.
    That was going to be one of the new surprises for you all, that was asked about recently so good timing. I've put it in for CMC but not CMD/CME at this stage.
    I even used American spelling for you all
  4. #84
    Nov 2010
    So much thanks Ross!!!
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  5. #85
    Just a question on this given it is a pretty big job to add these parameters in to ALL supported OS's.
    Would it be fair to say that if I just add them in for the OS's that have the option to convert to CSP that would be ok? (Which I've already done).
    These are all the OS's that have NO CSP option, is anyone using these on a regular basis that they actually need the extra limiters added in?
    11.55.10.28
    11.55.10.30
    11.61.05.00
    11.62.05.00
    11.62.05.01
    11.62.05.03
    11.62.05.05
    11.71.03.00
    11.71.05.02
    11.72.02.01
    11.72.03.00
    11.72.05.05
    Thanks,
  6. #86
    Jun 2011
    Works for me! I do not use any of those. All my customers trucks get a csp5 base, even for single tunes. I do that because of EDA.
  7. #87
    Mar 2015
    11.55.10.28
    11.55.10.30
    11.61.05.00
    11.62.05.00
    11.62.05.01
    11.62.05.03
    11.62.05.05
    11.71.03.00
    11.71.05.02
    11.72.02.01
    11.72.03.00
    11.72.05.05
    Thanks,
    Very fair proposition!
  8. #88
    Nov 2010
    Quote Originally Posted by comnrailpwr View Post
    Yep me too....csp base for all tunes.
    Les Szmidt
    2007 5.9 Dodge Ram
  9. #89
    Oct 2014
    Same here, all CSP
  10. #90
    Ok well here is an updated set of .calz files you can use to test with. These won't be included in the software installs yet until we get some feedback.
    Includes the new limiters and also the boost sensor rescale.
    Can I STRONGLY recommend you do some controlled testing before sending a bunch of tunes out to people if you have customers you need to update with these changes.
    I would recommend updating to this release first, then copy in the .calz files from the attached zip.
    Extract the attached zip in to:
    C:\Program Files (x86)\EFILive\V7.5\Calibrations\CMC
  1. High Rpm Miss 5.9
    By jumpman23302 in forum Cummins 5.9L
    Last Post: March 23rd, 2017, 02:08 PM
  2. High RPM Cold Start P/N
    By Protec in forum E37, E38 & E67 PFI ECM's
    Last Post: August 31st, 2012, 03:36 AM
  3. High RPM upon startup
    By Naf in forum Gen III V8 Specific
    Last Post: January 29th, 2009, 07:38 PM
  4. RPM remains high after accel
    By madprof01 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 26th, 2006, 02:55 AM
