Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 71
Thread: lc1 BEN factor for auto ve leaning out afr
  1. #41
    Sep 2017
    i have 5 wires coming out of my lc1, none of them are green or brown..
  2. #42
    Sep 2017
    okay I'm an idiot.. I do have a brown wire but it looks like it is going up to my wideband display gauge, can i just tee into it? still unsure about what ground I should be using, the one I am using seems to be doing something at least. on a side note I bought the car with this wideband setup so I'm unsure of how it is wired in.
  3. #43
    No, do not tee into the brown wire.
    You can instead re-program the other channel (yellow wire) to be 0-5V WB.
    The ground wires are either green or white.
    The black wire is not a ground, it is for initiating sensor recalibration, and for driving the LED.
  4. #44
    Sep 2017
    what do I want to set my 0v and 5v at for the lambda or afr and which should I use?
  5. #45
    For AFR: set 0.0V to AFR 7.35, set 5.0V to AFR 22.35...
    and then we will need a new calc pid CALC.WB.LAMBDA that calculates {CALC.AFR_LC11}/14.7 to get lambda...
    and then if you log GM.EQIVRATIO (instead of GM.AFR) the correction BEN is {GM.EQIVRATIO} * {CALC.WB.LAMBDA}
    I can add it to your calc pids file above (later tonite).
    So then, we're moving away from AFR (the only place where you need to set it is in B3601 in the tune), we going to log in Lambda...
    you will see that PE is around 0.85 Lambda (or so) regardless of the fuel you use
    ( this will avoid a lot of confusion between B3601, wideband, and the actual fuel )
  6. #46
    See attached calc_pids.txt... use the pid CALC.WO2BEN, remember to select all of its dependent pids.
  7. #47
    Sep 2017
    dumb question, I just copy and paste that into "calc_pids.txt file, post it here, it's located under c:\user\<you>\Documents\EFILive\V7.5\User Configuration" correct? do I set it as a new document or overwrite my current one?
  8. #48
    Yes, download and copy/paste the calc_pids.txt file, overwrite the current one;
    then open it using Notepad or Notepad++ and look at it, if you see the units LAM and EQR defined near the top, then you have the correct file.
  9. #49
    Sep 2017
    okay so i have everything hooked up and all the correct pids selected, is this the tune I want to run to do the auto ve now? it has my afr set at 14.7.
    I also attached a log of testing everything hooked up and trying to get some cells on the map above a 50 count under the MAF tune. I'm not sure if the data looks correct, what do you think?
  10. #50
    Sep 2017
    okay so I ran the tune from the last post and did a few sets of the auto ve around idle and its commanding more and more fuel each time. I don't see where the auto ve is trying to command a certain afr or lambda. you can see in the log that the lambda is showing lean (over 1.0) but the afr is showing rich which my eyeballs can tell is true lol.
    sorry if this is basic stuff, I will tell you this though, I have learned a crap ton from you and doing all this the last few days. I really appreciate it and hope to help others some day.
  1. V8 Scan - Calculated Ben factor
    By Tre-Cool in forum Tutorials
    Last Post: September 12th, 2017, 06:34 PM
  2. Replies: 30
    Last Post: April 8th, 2017, 10:59 AM
  3. Ben Factor Question
    By EVI in forum E37, E38 & E67 PFI ECM's
    Last Post: March 17th, 2010, 11:01 PM
  4. Auto VE Ben Factor
    By shane in forum Gen IV V8 Specific
    Last Post: June 20th, 2008, 11:34 AM
  5. Logging BEN factor with March 20th Beta?
    By Goldfinger911 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 06:03 PM
