Page 1 of 7 123 ... LastLast
Results 1 to 10 of 67
Thread: lc1 BEN factor for auto ve leaning out afr
    Sep 2017
    Default lc1 BEN factor for auto ve leaning out afr
    Hi, I have a 408 running an ls1a pcm and i'm trying to run the auto ve tutorial. I followed it step by step and when I copied and pasted the BEN chart into my backup VE table it was a .8 multiplier across the board and it leaned the motor out even more then it already was. I attempted a second log of data to get even closer but was so lean the car just fell on its face after leaving the driveway I had to load an older tune back in. I was expecting to have some 1.x numbers on the chart since at certain rpms I was running a little lean. I'm still a beginner at tuning but I have done a lot of searching and can't find an answer. Something that seems funny is the tutorial wants the commanded AFR logged and it shows 8.62, I'm running e85 so I have my stoich input set to 9.7 i believe but I don't know why it wants such a rich commanded AFR.
    I attempted to attach my auto ve log, hopefully it shows my BEN factor and anything else you may need.
    thanks for any help/suggestions
    Set Stoich back to stock (14.63 for F-car or 14.68 for Y-car) in the tune, and redo AutoVE
    ( the LC-1 reports AFR based on stoich 14.7, so the PCM's commanded AFR must be based on the same Stoich (14.63 and 14.68 are suffciently close).
    It also looks like your widebands are not working.
    Default ...or do this...
    Set B3601 Stoich AFR to 9.7 in your tune...
    and then do either one of these:
    a. create calc pids for LC-1 AFR based on stoich 9.7 and BEN based on this AFR (e.g. BEN is {CALC.AFR_LC11}/14.7 * 9.7/{GM.AFR}).
    b. create calc pids for LC-1 lambda and BEN based on this (e.g. BEN is {CALC.AFR_LC11}/14.7 * {GM.EQIVRATIO})
    I prefer b.
    ( of course you combine the math 9.7/14.7 = 0.65986 )
    If you use Lambda and/or EQR instead of AFR, there will be less confusion
    ( and NA PE should be set to about 0.85-0.86 regardless of stoich AFR )
    Sep 2017
    okay so I had my 3601 table set to 9.71 while i was attempting to run the auto ve, if I switch it over to 14.7 while running e85 won't the computer lean the motor way out? I typically log everything in lambda and cross reference it to an e85 chart to keep things more simple. why do you think my wideband isn't working? right now i'm running with no 02 sensors just an open loop tune with MAF support. I'm trying to dial in my VE table so I can run with no MAF and have more control over fueling. The way its setup now when I make a change to the VE table the AFR never changes, the MAF must be doing all the talking.
    Sep 2017
    so I just looked on the efilive help tutorial on how to create calcpids and I don't fully understand how to do it. I think I will try setting my 3601 back to 14.7 and see what happens, I have my lc1 display set to show afr based on e85 stoich so if it gets crazy I'll just shut it down, plus I log in lambda anyways so I should see it on there as well.
    Quote Originally Posted by 98camaro408 View Post
    Yes, that's what will happen... I was trying to point out that working with AFR make it harder and confusing... so I then wrote the next post about calc pids.
    Its reading mostly 7.8...
    Are you seeing a MAF DTC...?
    If you don't see a MAF DTC:
    the PCM will continue using the MAF, and if the MAF is not physically present, the PCM calculates what it should/might have read.
    Do this: set B3601 to 9.7 ( there are kits to measure alcohol % content in gasoline, then you can cross-reference it to the stoich AFR to use).
    Then let's take a look at your calc_pids.txt file, post it here, it's located under c:\user\<you>\Documents\EFILive\V7.5\User Configuration.
    Sep 2017
    that is a correct reading, my lambda showing 7.8 is my actual afr when I have the MAF fail set to 1, my VE table is set to run pretty rich as I believe it suppose to during the first run with the auto ve tutorial (it says to add 15% to the entire table I think). my wideband calibrated to e85 shows around 12.6. when i run with my MAF tune I idle around 16 afr and cruise around 12.5 afr at 2k rpm.
    right now i bounce between 2 tunes, one runs pretty good with the MAF activated, the other is setup with the higher fuel added to the VE table and the MAF set to fail. I run the second tune trying to dial in my VE table but so far no luck, I played with it last night but had some technical difficulties last night with my laptop battery and didn't want to lock my pcm.
  1. V8 Scan - Calculated Ben factor
    By Tre-Cool in forum Tutorials
    Last Post: September 12th, 2017, 05:34 PM
  2. Replies: 30
    Last Post: April 8th, 2017, 09:59 AM
  3. Ben Factor Question
    By EVI in forum E37, E38 & E67 PFI ECM's
    Last Post: March 17th, 2010, 10:01 PM
  4. Auto VE Ben Factor
    By shane in forum Gen IV V8 Specific
    Last Post: June 20th, 2008, 10:34 AM
  5. Logging BEN factor with March 20th Beta?
    By Goldfinger911 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 05:03 PM
