Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 54
Thread: 2018 6.7 C&C Tuning Issues
  1. #21
    Aug 2014
    Yea I don't know. I probably won't even try to start it if it does work, because I imagine the security will go nuts.
    I'll give it a go and report back.
  2. #22
    Aug 2014
    Update: I can Licence the computer but when I flash it it is failing right at the end of the flash. Error $0340 Download not accepted. Trying to flash a stock file.
Name:	Not Accepted.PNG
  3. #23
    Yeah, unless the digital signatures have been disabled (using a BullyDog, Fleece etc) you will only be able to flash stock files.
    As the $0340 error code description says:
    For Cummins controllers: Controller contains security to prevent modified tunes being programmed.
  4. #24
    Aug 2014
    Yes I know I am trying to flash an older Stock file so the BD can talk to it.
  5. #25
    Aug 2014
    Do you have any 2018 stock files that I an try so if this doesn't work I can at least go back to stock. I have 10-17 files only
  6. #26
    Do you know what was in it originally? 32370831AD etc
    Yes I do have 2018 files.
  7. #27
    Aug 2014
    Quote Originally Posted by gmpx View Post
    do you know what was in it originally? 32370831ad etc
    yes i do have 2018 files.
    31321831ad
  8. #28
    Aug 2014
    I've tried 15' 16' and 17' files all with no luck, they get right to the end and fail, as if you were flashing a modified file, but these are all bone stock. I am on the latest software and firmware.
  9. #29
    Close enough to get you going again....
  10. #30
    Quote Originally Posted by BigCE View Post
    Ah I see why, they've changed the signing key for the 2018's, only stock 2018 files will work on 2018's.
  1. 2018 Zl1 Camaro A10 support?
    By ringram in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 28th, 2017, 09:49 AM
  2. Replies: 3
    Last Post: August 11th, 2017, 12:39 PM
  3. Starting issues? B0102 & B5909
    By onegonewild in forum Gen III V8 Specific
    Last Post: January 1st, 2010, 07:08 AM
  4. ECM, TCM, PCM & BCM Issues Who's the Expert
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 7th, 2008, 01:30 PM
  5. Latency issues with 98Fbody & V2
    By Doc in forum Gen III V8 Specific
    Last Post: August 12th, 2007, 03:01 PM
