Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 54
Thread: 2018 6.7 C&C Tuning Issues
  1. #31
    Aug 2014
    "Script finished successfully" Yay now to figure out how to unlock this computer without a BD.
    I cant open that file maybe I need a 7.5 update, is it a Asin file this is a 4500 C&C truck.
  2. #32
    They are not mapped yet, I only posted it so you could recover the ECM.
  3. #33
    Quote Originally Posted by BigCE View Post
    You said it had
    31321831AD
    I posted...
    31321831AC.ctz
    My file was for the correct vehicle based on what you said, just one release earlier than what was in it.
  4. #34
    Aug 2014
    You said it had
    31321831AD
    I posted...
    31321831AC.ctz
    Thanks again for all the help. At least if we have to give up, the truck will still work.
    Currently trying to figure out another way to "unlock" the computer, if anyone knows what software/tool can be used please pm me.
  5. #35
    Nov 2010
    Anything new on this Ross? Got a 2018 3500, are we able to flash a 13-17 file in to get the edge or bullydog to unlock?
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  6. #36
    Aug 2014
    They will only take a 2018 file, until you unlock the RSA security. So the BD and Edge won't work.
  7. #37
    Contact Fleece Performance, they have unlocked a 2018 ECM (not using BD etc).
    Cummins changed the digital signatures on the 2018 ECM too so the earlier tunes will not flash in even if they are stock, must be 2018+
    Even when the 2018 ECM is unlocked the problem still exists of the Security Gateway module on the vehicle, bench programming once the ECM is unlocked is the only option at this stage.
    Yes all this is a pain but it is the way things are heading for everything, it's not 2007 anymore
  8. #38
    Dec 2013
    Maybe a flash harness is in order. leave the PCM mounted but have a long flash cable to plug in. Saves a bunch of time.
  9. #39
    Yeah, I was thinking the exact same thing. Sure it adds more expense for the owner but at least it is a solution, better than owning a L5P
    I'll send the guys at EFI Connection a message because they already do a bench harness for the CM2350B so a slight tweaking of it could work for doing it on the vehicle.
    https://www.eficonnection.com/home/p...amming-harness
  10. #40
    Feb 2012
    What about adding the cm2350b to the HD v2 and flash trough the back bone on the j1939 buss? No messing with the ecm connections (pia to get to).
    Sent from my SM-G900V using Tapatalk
  1. 2018 Zl1 Camaro A10 support?
    By ringram in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 28th, 2017, 08:49 AM
  2. Replies: 3
    Last Post: August 11th, 2017, 11:39 AM
  3. Starting issues? B0102 & B5909
    By onegonewild in forum Gen III V8 Specific
    Last Post: January 1st, 2010, 06:08 AM
  4. ECM, TCM, PCM & BCM Issues Who's the Expert
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 7th, 2008, 12:30 PM
  5. Latency issues with 98Fbody & V2
    By Doc in forum Gen III V8 Specific
    Last Post: August 12th, 2007, 02:01 PM
