I followed the AutoVE tutorial to a T. I disabled P0101-103 in the C6002 screen. I unplugged the signal wire at the MAF. Everything was great. I wasn't getting a check engine light.
Last night I hooked up my Dakota Digital dash and got it working good. Now the check engine light is on. For awhile I was using a LED for the check engine light. When I read the code its a EPA pending and PC code. I made sure my Freg fail is set to 1Hz.
If I turn them off in the DTC processing enablers the car will barely run and has no throttle.
How do I get this code to go away while I am in SD mode tuning the VE?
