Results 1 to 8 of 8
Thread: Can't copy segments anymore
    Sep 2007
    Default Can't copy segments anymore
    Hey, long time no see. Question, did the latest update eliminate segment copying? I just tried to upload a tune for a 2001 Silverado as an alternate to a tune for a 2000 Silverado so I can copy the segment over, and it says it won't allow it because the operating systems are different. I've compared these two tunes in the past, as both tunes are licensed to me. Before I updated my setup, this worked with no problems. The 2001 has OS 12208322, the 2000 has OS 12212156. I tried checking the tutorials and looking for other threads on the site but had no luck. Thanks.
    You can only copy segments from same OS id's... you can't copy from different OS's... it's always been like that.
    Sep 2007
    Except I've done it before, because I've copied a newer system into my 2000 model in the past. The factory OS for my truck was 09381344, it now has OS 12212156. Am I missing, or misunderstanding something here?
    Quote Originally Posted by Telco View Post
    It has never been possible to copy segments between operating systems using the EFILive software. Even if you did manage to somehow physically copy the data from a segment in OS 09381344 to the same segment in OS 12212156, the calibrations from 09381344 would not line up with what the OS 12212156 expected.
    You may have had both operating systems open in two versions of the EFILive V7 Tuning Tool software and used copy/paste to copy the data from one tune file to another. But that's the only way you'd be able to get the calibration data from one OS into a different OS.
    Sep 2007
    I've attached my factory original program and the one that's in the truck now. Did the same for my mother's truck as well. It worked pretty well at one time. Unless perhaps I'm thinking I did something but actually did something else? Thanks.
    Jan 2010
    Looks like you did a full flash of a newer operating system than what the vehicle originally came with.
    If I had to guess, you flashed a 2001-2002 operating system into a 99-00 vehicle.
    Sep 2007
    Quote Originally Posted by 1FastBrick View Post
    That does ring a bell. Still, based on this I'd think that I would be able to compare a 2001 model truck. I found another program that would load, and it was for a 2002 model truck. Thanks folks, I think this will cover me for now.
  1. Stock binary segments
    By computerjlt in forum E47 LUZ 2.0L (Family-B) Diesel
    Last Post: August 11th, 2016, 03:48 PM
  2. copying trans segments
    By smellyflange in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 3rd, 2014, 11:37 AM
  3. one or more invalid checksum segments
    By SGFastMax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 16th, 2010, 05:22 AM
  4. E38 w/ No transmission Segments
    By Shupe in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 14th, 2008, 01:32 AM
  5. Fuel Segments for 1998 T/A
    By KAZ MotorSports in forum Gen III V8 Specific
    Last Post: May 14th, 2008, 05:12 AM
