Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: How's it coming guys?
    Nov 2003
    Default How's it coming guys?
    Any progress? Any problems? Keep us updated...
    Default Re: How's it coming guys?
    Quote Originally Posted by Drake
    Hi Drake,
    Thanks for checking back to see how things are progressing, speaking as the hardware guy, that has been delayed slightly, but it's for the better.
    The prototype/development adaptor that was posted on the web site has been upgraded, we decided to ditch RS232 totally, so the new adaptor which is being manufactured as we speak (just prototyping, not production runs) will be USB2.0 and will have an another A/D input, so that now gives you 2 x A/D inputs to log addtional data with along with the normal EFILive data.
    This will be really handy for those with a WBO2 and say a boost sensor, you will be able to log both at once.
    So as far as the hardware goes, we are kinda at the mercy of the suppliers etc at this stage as to when the new USB version will be ready for testing, but it's all looking good.....
    Trust me, we are not sitting around twiddling our thumbs.
    Remember, suggestions of what you would like to see included are always welcome.
    As for the software, Paul 'might' respond to that.......
    Lifetime Member Steve Bryant's Avatar
    Feb 2004
    Default Hardware Interface Question/Suggestion
    I am an avionics (aircraft electronics) engineer and a former diesel truck mechanic who loves automotive technology. I currently use EFILive Pro with Bi-directional controls, V 6.3 Beta.
    I am extremely glad that you folks are working on FlashScan. USB 2.0 is really the way to go at this point in time. RS 232 ports aren't even included on many new lap tops. Also the through-put of USB 2.0 rivals fire wire although it is much more versatile and is backward compatible.
    Now to my question. How do you plan to interface with the analogue devices?
    I know that the prototype shows terminal blocks with screws, but I doubt that that will be your approach. You need some type of robust plug and receptacle system where the user can buy an additional plug if needed anywhere in the world. The contacts need to be low resistance, self-cleaning and capable of at least 1,000 disconnect/reconnect cycles without deterioration. Banana jacks might be a solution. A sub D series connector like the Serial Port/RS 232 connector would also probably work, but I don't know how comfortable the average hobbyist (or pro) tuner would be about working with these. Both are used world-wide as are DIN series connectors, but these fail the robustness criterion.
    Default Re: Hardware Interface Question/Suggestion
    Quote Originally Posted by Steve Bryant
    Well, RS232 is still way faster than what the PCM will pump data out at, the PCM only sets aside a certain amount of time to perform communications routines, but as you say, very few Laptops have serial ports these days so it seemed like the logical choice.
    My laptop (an NEC 2.4G P4) still has a real serial port which is great for some old DOS based automotive comms programs I have.
    Steve, this has been a problem on connector choice , personally I'd like a connector like a Lemo or Fischer etc, yeah, who's going to shell out $40 per connector and get the end user to assemble those!!, besides they probably wouldn't fit.
    Anyway, we have stuck with a terminal type connector, though on the new USB adaptor, the plugs are accessed from the side so you don't see them looking down anymore.
    One of the big problems is basically space, choosing a through hole connector to fit the height requirements is tricky. SMD connectors in my opinion are to susceptible to upwards force breakage or pad destruction.
    The terminals we chose (Weidmuller) can be purchased through someone like Rexel for example, they are an 'industrial' terminal connector, very robust. Screw connections were also chosen as not everybody has a soldering iron.
    All you need to connect the wires up is a good set of teeth (to strip the wire) and a small flat blade :lol:
    Aug 2003
    My complaint about the USB-only approach is that it generally consumes more CPU than RS232 on the laptop. I'm sure it will be a problem for my laptop, as of now I cant view the graphs in realtime with V6. Its a Celeron 350 processor.
    Feb 2004
    Default USB Primary Interface Versus RS 232 Primary Interface
    It appears to me that the EFILive folks are going to go either A - USB or B-RS 232 as the primary interface with the computer. That way, they do not have to go to the expense of developing and maintaining/updating two separate hardware versions (plus work-arounds for the inevitable related software issues). Either A or B can be adapted to interface with the other (although not in a fully seamless fashion in every case).
    For a limited production device like FlashScan, it is extremely expensive to develop, maintain and stock in inventory two families of hardware devices. Although my three year old laptop has both RS 232 and USB 1.0 ports, most new laptops only have USB. In fact, RS 232 is being phased out as an interface protocol industry-wide on new devices.
    I don't mean to be harsh, but it seems like you are getting on the ragged edge of "meeting the minimum hardware requirements." Most of us here are not "made out of money" and I certainly include myself. However, if you currently "can't view graphs in real-time with V6," the added functionality and features of FlashScan may be more than your current laptop can handle. There are some fairly low-cost alternatives. For instance, you could buy a recently obsolete model (probably below 1 GHz processor with both USB and RS 232 or a factory reconditioned model with a new guarantee. You wouldn't have to buy the cutting edge technology.
    One other thought I would like to add. Can your LT1 in the '66 Impala be programmed as if it were a LS1/LS1 series PCM. Maybe that is just your handle and you have another vehicle with an LS1 powertrain. Anyway, I'm just thinking out loud and I would welcome your comments.
    Lifetime Member emarkay's Avatar
    I agree that the serial port is a dinosaur, but my approach has always been LCD (Lowest Common Denominator) - or in other words cheap as one can get. I understand that there will be NO RS232 (serial) support, which (IMHO) goes against the LCD logic, but as is well stated, supporting 2 interfaces is expensive on such a limited market item.
    My Pentium 120 laptop (can you say the quintessential LCD device) is no longer a contendor, but I do have access to a "modern" Dell laptop I can borrow from the University.
    BTW, last time I checked, for USB support in a decent laptop, it was still about $500 or so on Ebay... Half a thousand bucks is a major purchase for most people...
    Maybe I can "mooch" a schematic for a serial version and "home etch" a few PC boards for us Luddites?
    Early EFILive V5 user - Upgraded from AutoTap for DOS!
    2000 Chevrolet Camaro Z28, A4 - For occasional day trips...
    1984 Chevrolet Caprice Classic - For the family...
    1989 Honda VTR250 - For me and me only...
    Quote Originally Posted by emarkay
    I picked up a Toshiba laptop, Pentium 130MHz with USB for $260 NZ dollars - which is only USD $180.
    That is our lowest specification machine on which we test EFILive.
    Ok, so it died about 6 weeks after I purchased it. Motherboard failure - but it only cost NZD $60 (USD $40) to get the whole laptop *replaced* with another comparable model from a local laptop repair company.
    Default Re: USB Primary Interface Versus RS 232 Primary Interface
    The USB/RS232 support is not an exclusive "either/or" deal. The FlashScan personal cable will be USB only. However we are also developing a flashscan workshop cable that will be larger (about twice the size of the personal cable) and it will contain more features.
    Such as:
    - More memory for longer black box logging.
    - More A/D convertors (4 instead of 2)
    - LCD display for displaying DTCs and other info - with no PC required.
    - Both RS232 and USB interfaces.
    We would have supported RS232 and USB in the personal version but the hardware/chipsets required to do that, will not fit in the small flashscan personal interface enclosure.
    OK - I should have also clarified the $500 laptop with +500 mHz and a few hundred megs of RAM... Would at least want to have something worthy of the "new century" If I was shopping around....
    BTW, just keeping the thought proceses open - glad to hear the clarification on this issue!
    MRK
  1. Race day coming up. What to log?
    By onegonewild in forum Gen III V8 Specific
    Last Post: July 2nd, 2009, 02:42 PM
  2. What is the world coming to?
    By GMPX in forum Lounge
    Last Post: July 10th, 2008, 07:46 AM
  3. New PCM Coming
    By roy in forum General (Petrol, Gas, Ethanol)
    Last Post: December 14th, 2006, 06:36 AM
  4. When is V2 coming out?
    By BLASTER in forum General (Petrol, Gas, Ethanol)
    Last Post: February 13th, 2006, 06:07 AM
  5. When is LLY tuning coming??
    By Redline Motorsports in forum Duramax LLY
    Last Post: January 1st, 2006, 06:24 AM
