Results 1 to 5 of 5
Thread: barely running after calibration only flash
    Feb 2012
    Default barely running after calibration only flash
    Hi , its a lq4 6.0 with ls3 heads, intake , 42 lb ls3 injectors, throttle body, ls1b controller, return style fuel system . I am running a 3bar COS , its a N/A setup . Everything was running good , I was dialing in the VE . Went for a drive , pulled over did a calibration only flash . It barely started , idles really rough for 10 secs and dies. Did a full flash no luck . Fuel pressure is good , everything checks out ok . Don't know where to go from here . I am attaching my file , any help would be appreciated .
    Post the previous running ctz.
    Try doing another cal flash.
    Also, side note (after you get it running):
    - if you're running boost, you have too much HO spark timing.
    - you have insufficient PE fuel (even for NA)...!!!
    Feb 2012
    Thanks for the reply joecar . Its the fuel pump or the regulator most probably the pump :( . Hooked up a gauge goes to 55 psi and then settles at 20 psi weird . Its a new walbro 255 pump with maybe 8 hours on it . Was a coincidence that it went out right after I flashed the computer . Not running boost hence the high timing . Thanks for looking through the tune , I will definitely bump up the PE values .
  1. Cruise not working after calibration flash....two vehicles
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: November 3rd, 2016, 08:22 AM
  2. Replies: 11
    Last Post: September 4th, 2013, 09:00 PM
  3. Replies: 4
    Last Post: February 23rd, 2010, 05:15 AM
  4. Rough running after flash and return to stock, TPS problem?
    By Whodunnit in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: July 27th, 2009, 10:57 AM
  5. Need HELP cant use flash calibration only??
    By turboolds in forum FlashScan V2
    Last Post: October 1st, 2008, 12:47 PM
