Results 1 to 3 of 3
Thread: E40 Bench Harness
    Jan 2009
    Default E40 Bench Harness
    The on-line tutorial for Bench Harnesses only has connections to the E40 blue connector and the only ground indicated is to pin 7 which is the E40s Acc Pedal Pos Sensor 1 Low Reference. Shouldn't ground be provided to Black 73 instead?
    They are all internally connected, for bench programming where there is little current draw involved using that ground is fine.
    Oct 2020
    I hate to bring this up from the dead....But this is my exact question. So just to clarify. E40 Blue connector Pin 7 goes to OBD port pin 4 and 5 then to ground.
    Also would Black 73 work just the same? Any way better than the other?
    Thanks for Clarification.
  1. T-87 Bench Harness
    By Chavez91 in forum Allison 5 & 6 Speed
    Last Post: April 17th, 2016, 08:03 PM
  2. Bench Harness?
    By GAMEOVER in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 31st, 2009, 11:33 AM
  3. bench harness
    Last Post: June 15th, 2006, 05:09 AM
  4. Bench Harness
    By Biodiesel66 in forum Duramax LB7
    Last Post: May 3rd, 2006, 09:34 PM
  5. bench harness
    By madprof01 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2005, 03:25 AM
