Results 1 to 3 of 3
Thread: How to eliminate CL/LTFT/STFT
    Jun 2016
    Default How to eliminate CL/LTFT/STFT
    Hey Guys,
    How do you completely disable CL/LTFT/STFT (AutoVE ) I don't want the wideband read stoich .
    My goal is to Run Full OLSD without going through COS
    is that possible?
    00 Camaro Z28
    398ci lq9 w/ ls9 heads , Holley Hi ram intake
    Th-400 , 5k stall
    9.7 cr - 94mm BW Turbo
    Super Street
    03 Sierra, L92
    398Rwhp/416Rwhp
    B3801 (LTFT correction): set to Disable.
    B4205 (CL temperature enable): set to max temperature.
    B4206 (STFT correction in OL): set to Disable.
    if your tune does not have B4206, then make sure there are no stoich cells in B3605.
    ( if you're running an LS1B COS, then make sure there are no stoich cells in B3647 and B3649 )
    Yes, you can run OLSD with the OEM OS (i.e. non-COS)... you won't get adaptive spark (it will run from LO Spark table), and if your OS has a Backup VE table it will run from that (i.e. not the Main VE table).
    And, you must make sure that it is running in SD by observing the immediate presence of a MAF DTC.
    Jun 2016
    Great
    Thanks Joe
    00 Camaro Z28
    Th-400 , 5k stall
    Super Street
    03 Sierra, L92
    398Rwhp/416Rwhp
  1. STFT only NOT LTFT
    By maudyZ28 in forum Gen III V8 Specific
    Last Post: April 16th, 2011, 01:41 AM
  2. e67 and ltft and stft
    By MECHAN12 in forum E37, E38 & E67 PFI ECM's
    Last Post: March 26th, 2011, 05:23 AM
  3. Can someone clear up some STFT/LTFT confusion
    By stigmundfreud in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2010, 05:26 AM
  4. STFT and LTFT tuning
    By nathans1987 in forum Custom Operating Systems
    Last Post: September 11th, 2009, 04:44 PM
  5. MAF tuning via LTFT/STFT?
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: April 4th, 2007, 05:25 AM
