Thread: LS1b E85 tune questions
    Member O1Z06's Avatar
    Jan 2011
    Default LS1b E85 tune questions
    I am setting up an E85 only tune, manually not flex fuel, on the 02020005 OS and I have done a few searches where all I need to change is B3601 to the stoich ratio of the blend used (using an Innovate gauge for content). If this works how do you go below 10 AFR which is the efi limit? I see that the controller limits have a much wider range so if I put in a value like 9.8 AFR and flash will it truly be 9.8 in the controller? When efi saves it goes back to 10. I am a bit confused so any help with this would be appreciated.
    2001 Z06 512K Road Runner COS5
    LSx 427, Comp 7075 TT in progress
    I just leave it on the gas scale and add my fuel to the ve table.
    Jan 2011
    Yes that would work but VE is for airflow and would probably skew some other related tables and transients. I'm already scaling for the 512 g/s airflow. Suppose I could also scale my injector FR again to.
    Just came across this and it appears it's a false limit: https://forum.efilive.com/showthread...l=1#post199107
    Good to know, hopefully it will be this easy.
    As a side note, even the 1MB flex OS 2D table shows 10 AFR as minimum limit but the high ethanol content cells the value is <10.
    LABELS Ratio of Air to Fuel for Stoichiometry (AFR)
    Ethanol % Value
    0.00 14.681005
    6.25 14.321680
    12.50 13.979524
    18.75 13.607975
    25.00 13.255665
    31.25 12.921137
    37.50 12.564418
    43.75 12.190477
    50.00 11.838152
    56.25 11.473391
    62.50 11.130436
    68.75 10.778948
    75.00 10.422393
    81.25 10.063883
    87.50 9.706162
    93.75 9.351599
    100.00 9.002199
    When you do set B3601 to some value less than 10.00, confirm this by logging GM.AFR, it should show your B3601 value (when fueling at stoich).
    Aug 2016
    I think with the latest EFILive update you can set values outside the limits. Like Joe said, if you do that double check that it's actually commanding/fueling your sub-10 AFR.
    Sent from my Nexus 5X using Tapatalk
    Mar 2009
    Most E85 at the pump is E70-E75 and the value ends up being over 10. At least out here in CA. My E85 tune is set at 10.3 and my trims don
  1. Replies: 5
    Last Post: June 20th, 2017, 06:06 AM
  2. FIC 1000cc INJECTORS + E85 - 2011 Cad CTS-V 6-speed M/T = Questions
    By GR8GAME in forum E37, E38 & E67 PFI ECM's
    Last Post: December 13th, 2016, 04:00 PM
  3. 2 Quick Questions: LS1B Tuning
    By truethinker in forum Petrol / Gas
    Last Post: August 19th, 2015, 10:50 AM
  4. Need help for a 5.3 twin turbo/E85 SD Open Loop Tune
    By Sinister in forum General (Petrol, Gas, Ethanol)
    Last Post: April 17th, 2012, 01:36 AM
  5. AutoVE tune on E85 help
    By V8Hilux in forum General (Petrol, Gas, Ethanol)
    Last Post: October 29th, 2010, 04:16 PM
