Thread: E67 O2 Sensor timing
    Sep 2017
    Default E67 O2 Sensor timing
    Hello -
    Been fighting with a low RPM surge\buck while driving on 2010 ZR1 that only has headers. Car is running well in open loop tuning for MAF but as soon as we go back into closed loop the surging\bucking starts back up again.
    Since the O2 sensors Have been moved further down stream is there a way to slow down the closed loop response like on older ECM's?
    Jul 2003
    What operating system?
    Sep 2017
    OS number is 12635947
    Jul 2003
    Can you post the file?
    Sep 2017
    ZR1 Stock File 7-18-17 1251.ctz
    Jul 2003
    Code:
    [B9544]
    ;         Description
    DESC.001 = STFT Base Delay VS Airflow Mode
    ;         Seg Caption                          Major            Minor            Vis Dis 2D Grp
    VIEW =      2 "STFT Base Delay VS Airflow Mode"         "Fuel"     "O2 Trims"                1  2   0   0
    ;         Address(es)                      BitOff Bits Typ Inv
    ADDR =     1DFEC8                                0   16 SNM   0
    ;         Units    Factor         Offset Prec MinLimit MaxLimit MinUser  MaxUser
    SI_SLOT =   ms  0.125             0   0   0      3000   0    3000
    ;         Body           Col            Row
    ULABELS = .              .              .
    ;         Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ;         Units            Labels
    SI_COL =    "Delay"          "ms"
    IM_COL =
    SI_ROW =  AirFlowMode         "0,8,16,24,32,40,48,56,64"
    IM_COL =
    [B9545]
    ;         Description
    DESC.001 = STFT Proportional Gain Vs mV
    VIEW =      2 "STFT Proportional Gain Vs mV"         "Fuel"     "O2 Trims"                1  2   0   0
    ADDR =    1DFEA4                                0   16 SNM   0
    SI_SLOT =   ms  0.000030517            0   3   0      2   0    2
    ;         Body           Col            Row
    ULABELS = .              .              .
    ;         Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ;         Units            Labels
    SI_COL =    .
    IM_COL =
    SI_ROW =  O2Error         "0.0,0.5,1.0,1.5,2.0,2.5,3.0,3.5,4.0,4.5,5.0,5.5,6.0,6.5,7.0,7.5,8.0"
    IM_COL =
    [B9546]
    ;         Description
    DESC.001 = STFT Proportional max vs airflow mode
    VIEW =      2 "STFT Proportional Max vs airflow mode"         "Fuel"     "O2 Trims"                1  2   0   0
    ADDR =    1DFE60                                 0   16 UNM   0
    SI_SLOT =   Factor  0.000030517            0   3   0      2   0    2
    ;         Body           Col            Row
    ULABELS = .              .              .
    ;         Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ;         Units            Labels
    IM_COL =
    IM_COL =
  1. LBZ BP sensor vs MAP sensor readings
    By Don Z in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 20th, 2017, 01:52 AM
  2. IAT 2 Timing correction tables e67 ??????
    By Y BE AVG in forum E37, E38 & E67 PFI ECM's
    Last Post: December 21st, 2015, 11:51 AM
  3. GMPP E67 and 8 pulse speed sensor
    By ProperTuningOG in forum E37, E38 & E67 PFI ECM's
    Last Post: April 9th, 2015, 09:23 AM
  4. E67 Timing issue
    By MattS in forum E37, E38 & E67 PFI ECM's
    Last Post: May 14th, 2012, 09:58 AM
  5. Billet LT1 Timing Cover - Clears Double Row Timing Chain
    Last Post: November 17th, 2009, 01:15 AM
