Results 1 to 2 of 2
Thread: Sensor problem
    Apr 2017
    Default Sensor problem
    Hello,
    I'm having problems with my Monaro VXR LS2 (E40). To give you some background as to what happened, I changed the clutch and flywheel and when I started the car I got an EML and the traction control was off (signaling a sensor fault), a quick check with EFI Live showed that the map sensor had a problem, upon inspection it was broken. I replaced the MAP sensor and the EML went away but the Traction Control remains off.
    I was told that when the car shows Traction Control off there is a fauly sensor somewhere, the problem is I don't know where. I've been told I can perform a full scan with EFI Live that will probably show me where the problem is, can anyone advise on how I do this?
    Many thanks
    In the V7 scantool:
    go Edit->Properties->Advanced and checkmark Check/Clear DTCs for All Modules, make sure all the buttons for Display DTCs are blue (i.e. active), and then click Ok.
    then go Info->Retrieve All Test Results... when this is donr, go view the results on the OBD II tab.
  1. LBZ BP sensor vs MAP sensor readings
    By Don Z in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 20th, 2017, 12:52 AM
  2. Map sensor problem in efi live scan tool
    By zayne0 in forum Petrol / Gas
    Last Post: October 22nd, 2014, 11:17 PM
  3. Problem with DTC PO342 Camshaft Position sensor circuit low
    By LSXstart in forum Gen III V8 Specific
    Last Post: December 3rd, 2010, 02:35 PM
  4. TPS sensor problem
    By mr.prick in forum Gen III V8 Specific
    Last Post: February 19th, 2010, 05:06 AM
  5. PID Problem w/BBB - Asked by Cougar 281 (FRPDES problem)
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 01:02 PM
Tags for this Thread
