Results 1 to 10 of 14
Thread: desensitizing knok sensors
    Nov 2014
    Default desensitizing knok sensors
    there seems little info about this on this site. any advice, tutorial i overlooked?
    im trying to get rid of random knock on cos3. most of the tables mentioned in the few posts i found are not there. 6246, 6247, 6228 are zeroed out. confusing.
    Oct 2006
    At what rpms does this knock occur?
    2006 Trailblazer
    Also try zeroing burst knock.
    Nov 2014
    as mentioned its random knock when accelerating (none at redline so far) but also in situations where engine cant knock, especcially in view of the high octane gas it drinks. im logging burst and its not related, i saw it only a couple of times.
    so which of the tables would be a good starting point? im talking about values of typically 0.5-2.0 degrees btw.
    Jul 2003
    B6250 and B6255 are the tables you are looking for to change. What are your numbers there?
    Sorry, somehow thread was dropped, I don't know what happened.
    Nov 2014
    b6250 is 15 up to 3200 rpm and 13 from there. 6255 is 13.
    is there a writeup or something somewhere? it looks quite involved. no idea what rpm and tps knock modes are. a lot of stuff multilying ittself. a/b tables are for when not in rpm or tps mode??? i would have thought 6242 is the one to play with (is 255). os 0202003(and a lot of confusion) here.
    btw, stock/original 6250 oscilates between 9 and 11 up to 4000 rpm and is 11 from there. no 6255, no rpm mode apparently, 6242 is 245.
    Jul 2003
    When the ECU is in transition meaning RPM is increasing it will use the TPS and RPM tables. whichever is higher it will use.
    When its in steady state it uses the per cylinder numbers.
    Oct 2006
    There's a page here, that might help.https://forum.efilive.com/search.php?searchid=2311546 ,
    2006 Trailblazer
    There's 11 pages here, that might help. https://forum.efilive.com/search.php...id=2308817&pp=
    That url is incomplete/broken, please post the complete url... thanks.
  1. O2 sensors
    By scottcmb in forum Gen III V8 Specific
    Last Post: January 14th, 2013, 07:06 AM
  2. Setting rear O2 sensors to act as bank 1 (primary) O2 sensors
    By T34418L31 in forum Gen III V8 Specific
    Last Post: November 6th, 2010, 03:59 PM
  3. o2 sensors
    By nathans1987 in forum Gen III V8 Specific
    Last Post: January 30th, 2010, 05:16 AM
  4. O2 Sensors
    By Elliott in forum Gen IV V8 Specific
    Last Post: August 20th, 2009, 12:39 AM
  5. O2 sensors
    By charlieNchains in forum Vortec V6/V8 Specific
    Last Post: July 26th, 2009, 04:41 AM
