Results 1 to 3 of 3
Thread: 2012 GMC 3500 develops problems 2 years after initial tune
    Oct 2017
    Default 2012 GMC 3500 develops problems 2 years after initial tune
    My 2012 GMC 3500 has suddenly developed problems that I can't seem to rectify. It was tuned/deleted almost 2 years ago and has been very trouble free this entire time. It's got an S&B CAI, and a new exhaust sans the DPF system. The DEF tank was also deleted completely. Other than that it's completely stock. The problems have started recently (roughly 70k miles since initial tuning/delete). It's been throwing the P0101 code for the last month. I clear it, and it eventually returns. I've replaced the air filter with a brand new unit from S&B, and have cleaned the MAF sensor twice to no avail. As of today, it is now throwing P0101 and P0103 codes. When you clear them, the P0101 code goes away for a bit, but eventually comes back. The P0103 code returns immediately upon starting the truck after you clear them. Today it also gave me a "Emissions Service Required" message in the info center with a mileage countdown until it locks the truck into an under 65mph mode. I've tried reloading the tune that has been in use on the truck this entire time, but that didn't seem to change anything.
    Anyone have any ideas?
    You have to troubleshoot/diagnose the P0101 and P0103 using the appropriate chart/table from the GM service manual or equivalent.
    You might want to contact whoever tuned it for you because EFILive doesn't have delete parameters for those trucks so whatever mapping was done would have been external to EFILive, hard to know what has been changed in that case.
  1. Replies: 0
    Last Post: October 31st, 2016, 08:30 AM
  2. Replies: 0
    Last Post: September 23rd, 2016, 06:55 AM
  3. 2012 Ram 3500 Stock tune 12351331AN Please?
    By crdth in forum Cummins 6.7L
    Last Post: April 15th, 2015, 02:57 PM
  4. ECT problems-2008 3500 lmm
    By sleepyrc in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 26th, 2014, 01:46 PM
  5. Data Logging an 09 GMC tuned with HP Tuners - Problems
    By TDFDiesel in forum E37, E38 & E67 PFI ECM's
    Last Post: April 26th, 2012, 08:38 PM
